Might be wrecking a R33 4 door soon (still in the process of paying for it). I need to wreck it down kind of quick so I'm hoping to pre-empt potential sale of parts before I accidentally throw bits away. I'm planning to keep the engine (motor, turbo, loom, ecu, Intercooler, etc), everything else should be forsale. It is a Series 1, manual, ABS model. Side impact pretty bad but glass is there.
Let me know if you are interested in buying some parts.
What front bar does it have?
Hey guys,
I have a pair of 16x8 +33 lightweight 5 spoke rims with 225/45 advan AD08R tyres on them that I need to get rid of. Tyres are 1000km old including 1 trackday. I kept them when I sold my mr2 a couple of months back but unfortunately the rims don't clear the brakes on my 32 and I've got 18's now so these are useless to me. Looking for $300 for rims and tyres together or I can separate rims for $100 and tyres for $250.
Feel free to PM or SMS with any questions or for pics. Number is 0433414424.
Cheers,
Drew
ONE OF A KIND - 1989 R32 GTS-T FOUR DOOR FOR SALE
Many hours and $$$$$$ spent to create this beautiful R32 rebuild.
Over 2,000 views in SAU Garage.
All receipts and rebuild history.
Very reluctant sale due to OS posting.
POA
CONTACT Robert Wilson - 0411 744 813 or PM
Stroked RB22 motor
Custom arias forged pistons and rings
ACL comp bearings
Balanced
Blueprinted throughout
Full block machine and relieved with oil restrictors
N1 oil pump modified
Crankshaft shotpeened,grubscrewed,oil collar fitted and micro-polished
Spool h beam rods with ARP 2000 bolts
Recon and ported head
Adjustable cam gears
Timing tensioner kit with gates belt and waterpump
Hi vol race sump with rear head drain
Cometic steel head gasket
Tomei 264 poncams
Tomei step 2 springs
Garret GT30/76 turbo
Intercooler
Custom catch can
650cc injectors
Splitfire coil packs
Z32 Air Flow Meter
Nistune ecu
Walbro 255 LPH hi flow fuel pump
Re-built four speed AUTO transmission with 1.5 torque converter
Pedders eXtreme XA Coil Overs
Hardrace Front Upper Adjustable Arms
Hardrace Rear Traction Rods
Hicas Lock Bar
Solid Rear Cradle Bushes
Slotted rotors with braided lines
3" exhaust with hi-flow cat
Vertex style body kit
King Wheels Camino Red 18x8
Federal 595RS-R - Front 225x40x18 Rear 235x40x18
Bare metal respray
Pantera leather seat trim by Alphaline Auto
Blitz Gauges 60mm - water temp, oil temp, boost
Momo Commando steering wheel
Memphis amp and speakers
Kenwood head-deck - DVD, handsfree, bluetooth
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
