How much do you want for the front bar, indicators and grille?
I'd give you a call but lost your number lol
Honestly, I don't know how much it's worth. I had a look around on ebay/forums and it's about $100 for the front bar? Feel free to make an offer though.
Stinkypoo. Can I get that cannon from the 4 door? I'm assuming it has been welded already?
Only asking as my cannon has the stupid silencer in it as per recent thread.
PM me cost and location if you could.
Thanks,
James
I haven't removed it just yet but another person has already contact me about it. I will let you know if the sale falls through.
ONE OF A KIND - 1989 R32 GTS-T FOUR DOOR FOR SALE
Many hours and $$$$$$ spent to create this beautiful R32 rebuild.
Over 2,000 views in SAU Garage.
All receipts and rebuild history.
Very reluctant sale due to OS posting.
POA
CONTACT Robert Wilson - 0411 744 813 or PM
Stroked RB22 motor
Custom arias forged pistons and rings
ACL comp bearings
Balanced
Blueprinted throughout
Full block machine and relieved with oil restrictors
N1 oil pump modified
Crankshaft shotpeened,grubscrewed,oil collar fitted and micro-polished
Spool h beam rods with ARP 2000 bolts
Recon and ported head
Adjustable cam gears
Timing tensioner kit with gates belt and waterpump
Hi vol race sump with rear head drain
Cometic steel head gasket
Tomei 264 poncams
Tomei step 2 springs
Garret GT30/76 turbo
Intercooler
Custom catch can
650cc injectors
Splitfire coil packs
Z32 Air Flow Meter
Nistune ecu
Walbro 255 LPH hi flow fuel pump
Re-built four speed AUTO transmission with 1.5 torque converter
Pedders eXtreme XA Coil Overs
Hardrace Front Upper Adjustable Arms
Hardrace Rear Traction Rods
Hicas Lock Bar
Solid Rear Cradle Bushes
Slotted rotors with braided lines
3" exhaust with hi-flow cat
Vertex style body kit
King Wheels Camino Red 18x8
Federal 595RS-R - Front 225x40x18 Rear 235x40x18
Bare metal respray
Pantera leather seat trim by Alphaline Auto
Blitz Gauges 60mm - water temp, oil temp, boost
Momo Commando steering wheel
Memphis amp and speakers
Kenwood head-deck - DVD, handsfree, bluetooth
AWESOME :thumbsup:
Os posting? Your desperate to get rid of it.
Reluctant sale? The price is too high.
Good luck.
My guess is you wont sell it before you get back.
Edited by D.I.Y. Mik
Desmond Regamasters
Anyone in ACT after some nice light wheels?
rough tape measure offsets
17 * 8 +30
17* 9 +38
overall good condition, couple of scratches and minor rashing as per pics.
front tyres are 225 yokahamas with some tread
rears are unroadworthy
Looking for $1800
Located in Canberra
Pm for details
go here for more pics
http://www.sau.com.au/forums/topic/449305-desmond-regamaster-17x9-and-17x8/
  • 3 weeks later...
Hi All,
I have the following stuff to sell all pickup in Canberra / QBN.
Price is make are offer on here or via PM... I need this stuff gone i wont refuse!!!!!!!!!
Reverse switch (that controls the reverse lights) Brand new genuine nissan.
http://imgbox.com/xqypXZoU
Plastic Box for POD
http://imgbox.com/oFvc0G3k
Clutch and Fan. Clutch is stuffed!!
http://imgbox.com/THybj6ju
R33 s2 stock exhaust... all the way from dump pipe to back.. good condition
http://imgbox.com/l0c2GHWp
R33 S1 ABS pump... OK condition should work fine though never tested (i had a s2)
http://imgbox.com/eAV1Owii
R33 Emergency tyre
http://imgbox.com/bmxZHrPT
BARGAIN:
1X R32 GTR wing fibreglass black with 1 stud missing but good cond.
3x R32 GTR plastic side skirts with smallish (one pretty large as seen in pic) cracks (repairable) but no where mint. In black. 2 LHS, 1 RHS
Paid a bundle for these but.... they need a good clean and I CBF'd.
Price: 1 Bottle of Bundy + 4 litres of coke Zero for the lot.
As is where is. And, you must pick up in a Skyrine / RWD car and do a skid on way out :woot: .
Land of the free: QBN.
PM me!
6 Pack? Otherwise they are going to the tip.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
