Garrett GT30, 0.82 rear housing. Internal wastegate.
$30 - Pick-up from Canberra preferred, can post at buyers expense.
Item has never been used, it was part of a GT3076R kit purchased from GCG a few years ago.
These are still $500-600new
Please Pm here, or call/sms 0431900505
Hey Zebra
Short Block is RB25
CP Pistons
Nitto I Beam Billet Rods
Oil restrictors Balanced and Machined ect
still has shrink wrap I had it built to handle over 400kw and can be inspected at workshop for serious buyers
no one is keen on buying the complete motor with warranty some im tying to sell it apart already sold the Nismo twin plate clutch and 9L High Energy sump
PM for Pricing or more details
for sale.. set up suit rb25.. garret 35/40 no shaft play very very low km. high mount manifold to suit. 3inch dump pipe down to muffler. 50mm turbo smart waste gate plumed back to dump only one tune and approx 500km on wastegate. dump pipe has standard exhaust sensor and a second one for digital AEM air fuel ratio gauge. $1700 fairly firm
Pm me or 0423730741
I 2x r33 diffs not locked running perfect $75 each
Adjustable rear camber arms and toe arms never tracked $180 for both.
R 25 head $50
Lots of other spears and parts on the car pm for pic
3x sets of wheels up wheels are 18s tyres ok $250
2x sets of 17s some with minor rash tyres all drive able some not road worthy some are $200 per set
Blitz return flow inter cooler $150 all pipes to the turbo and manifold
Aliminium radiator less then 1000km on it $100
Pm for more pix
TRUST/GREDDY oil filter relocation kit to suit RB engines (I presume they all have the same filter fittings?). Comes with hoses, clamps, relocation plate, mounts (well, everything the retail box contained). Never fitted or used.
http://justjap.com/trust-oil-filter-relocation-kit-nissan-skyline-ecr33.html
Apparent RRP of $389....can't recall how much I paid for it, so I'll just say half of that - $185 ono. Happy to post at buyer's expense.
Edited by Trozzle
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
