Selling a brand new Python 574
Alarm can be intergrated with your smart phone for keyless starting, phone disarming/ arming, GPS traking, Do not need this anymore will sell it for a cheap price of $180 ono
Item Condition: Brand New
Product Features:
  • Responder LC3 SST 2-way LCD Pager Car Alarm with1-Mile Range and Remote Start
  • Priority user interface and icon map
  • Priority 5-button user interface
  • Remote can confirm commands with tones, vibration, text and icon display
  • Remote notifies of security intrusions with tones, vibration, text and icon display
  • Powerful lithium-ion rechargeable battery with mini-USB charging
  • Integrated text display
  • Tone, vibe and display notifications and confirmations
  • Car finder
  • Fail-Safe starter kill
  • Revenger soft-chirp six-tone neo siren
  • Onboard Stinger Double-Guard remote-adjustable shock sensor
  • Warn-Away features a low-volume, brief warning signal for potential threats
  • Silent Mode alarming and disarming
  • Keyless entry with optional progressive driver's unlocking and ignition-controlled locking
  • Trunk Release
  • Manual transmission mode
Product Convenience Features:
  • One mile range primary LCD SST remote
  • Slim 5-button SST 1-Way companion remote control
  • Priority 5-button user interface with easy 2-car operation
  • Control Center with integrated status LED and valet switch
  • Virtual Tach RPM sensing
  • D2D serial data interface for Xpresskit D2D serial data interface modules
  • XpressPort dock for Xpresskit docking serial date interface modules
  • Onboard Flex Relays for remote start and light flash
  • Advanced remote start functions: Timer Start, Smart Start, RunTime Reset, and more
  • Active Temp Check displays internal cabin temp while remote start engaged
  • SilentMode2 alerts of intrusions without vehicle siren or light activation
  • Inputs for doors, hood and trunk monitoring
  • Progressive door trigger
  • NPCincluded (patented Nuisance Prevention software)
  • Ports for optional tilt, glass break, cabin and proximity sensors
  • 3 additional auxiliary outputs
  • 1-year Sonic Electronix warranty
Thinking about selling my R32 as a rolling shell (no engine, gearbox or diff). It will however come with another RB20DET, gearbox and diff with the sale. Not very pretty because I've been using it for drifting, but R32's look so cool.
It does have on it:
- Adjustable castor rods
- HSD coilovers but one dampener needs a rebuild (bound feels like it's blown out).
- Has Potenza front struts because of the coilover problem
- DVD player and motorised touch scren (1 DINN)
- Project Mu front brake pads
- Bosch 040 intank pump with relay from battery
- 2.5 months rego
- Hicas lock bar
- GTR rear cradle (suspension knuckles)
It will also come with separate:
- Original RB20DET (I was running a RB25)
- RB20 gearbox
- VLSD
- Flywheel, HD clutch/pressure plate.
After $2500, I think I can wreck it down for the same price. If you're after parts let me know and I'll consider wrecking it down sooner if I have enough interest. I might even put a RB30 into it in the mean time.
EDIT: No pics of it at the moment, any that I do have I don't want to post :P.
Anyone have a cheap 18" 365 35 tyre I can buy as I have a delainated one and I need to replace. Would be super helpful as the other rear is still reasnoble and I dont want to switch to the ugliest 17's in the world.
Cheers,
James
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
