18" DEEP DISH Manaray Sport VRS Wheels. Offset 35.
Looks great on imports, and wild on Skylines.
Rears run 265's and fronts 245's
Tyres are finished.
Usual gutter rash, and a little clear coming off but nothing that would stop you from buying them.
Pick up only from Queanbeyan.
$300
SemiSlick / Road Tyres. Potenza Adrenalin RE002 245/40/18 X3.
Amazeballs tyres.
2 Really good with heaps of tread, 1 half tread worn.
Only selling as one was slashed, and I just bought a whole new set.
Won't separate, take the 3.
Grab a bargain!
$200
Bellona Rims 19" with 2 almost brand new tyres. 19x8. Offsett 43.
Buy tyres get free rims! 2 tyres 245 / 40 / 19
One rim hit a pothole but is fixable. Was quoted $220 - cheaper if you take the tyre off. Bit of clear coat coming off.
Looks Baddass on a big car.
Usual gutter rash.
$300
Boost Tees:
Regular $25 Posted or pick up Queanbeyan and a free beer.
High Boost Tee from Turbo Tech. From memory it was good for 30psi or there abouts. (Doubt anyone would do that though, but anyhoo)
$35 Posted or pick up in Queanbeyan and a free beer.
Tyres are finished.
$300
SOLD
Amazeballs tyres.
Grab a bargain!
$200
SOLD
Pair of 15x8 40p with 275/60r15 M&H Drag Radials should fit most skylines with rolled guards $750
Sponsor me these and you can both probe my chambers
Guys I'm moving to the UK so getting rid of everything at rock bottom prices.
ORC 559 twin plate clutch. heaps of meat. but needs a new throw out bearing...cause its gone missing.
heaps of meat $400.00
GCG td06-20g bolt on rb20/rb25 turbo. complete with all lines and fittings
used for less than a hour before the head lifted. this is the first one gcg sold and its awesome. matches their high flow but everything is new!
I paid 1425 + freight
its yours for $1100.00
Haltech E11v2 r32/r33 plug in ecu and 3 bar haltech map sensor. This has been in the club forever. was on sins gtr. then owned by tats and shell, then I bought it
$600
Xspurt 1000cc short injectors in an aeroflow rail and turbo smart FPR1200 regulator. This is setup to go under the factory rb25 plenum
its about 6 months old and comes with a loom to fit r33 rb25s. I paid 1300ish
I would like to swap it for some factory injectors and rail plus + $600 cash.
photos and more details to follow.
best to pm me. not really open to offers because its cheap as shit already.
cheers
Andrew
Also selling the beloved car. didn't think id ever sell this thing.
but as above an opportunity to move the uk has come up and cbf dealing with a car sitting here.
so 93 mod R33 gtst
Pretty rough around the edges. and it will be sold as a near stocker unless you want to buy it with all the above parts.
its getting a new head gasket and arp head studs currently. bores look pretty good and can provide pics if needed. I'm not reusing any of the under plenum hoses, Just waiting on an order to arrive from Amayama, all gaskets will be replaced with Genuine Nissan items.
Has BC BR coilovers, r33 GTR seats, a blitz turnflow front mount, fresh "race brakes sydney" rotors and pads front and rear, 80mm momo corsa exhaust and 3"front/dump pipe. Genuine Sparco 17x9" wheels with Federal 595 RS-R tyres with 70ish % tread and some sort of Exedy HD clutch.
ACT rego until Feb
I can't believe I'm doing this....
but
$3k come get it
Best to get me via pm and I'll shoot you my number
but yeah. keen to sell. gotta come up with 10k before July...so buy my junk!
12278802_10153259539731699_3728534172914
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
