R32 GTR cradle no hubs/brakes/diff or driveshafts. Has a HICAS lock bar and knuckles. $100
R32 GTR rear struts with king springs. One has damaged thread on top of the shock. $80
Still got the R32 GTR HKS Drag rear coilovers $300
FJ 720 do you still have the HICAS lock bar on the R32 rear cradle?
K&N panel filter for RB26DETT part no. 33-2031-2. Used for approx. 20k. Includes new bottle of power kleen and almost new can of spray oil (only used once for initial light coat). $80 ono.
price drop $60
Walbro 400l fuel pump did less than 500km, come with wiring and new strainer $50
Rb30 fuel rail new with an6 and an8 fitting also to suit 14mm or 11mm injectors with adaptors all included $150
Rb25 candy blue rocker cover $250
Rb25 clear cam cover used still in good condition just needs a good clean $50
Rb25 head with stock cams stock valve spring etc but no valve seals or rocker covers $100
Rb30 head $100
Rb25 block with blown piston ring $100
Rb30 block $150
Rb25 S1 afm $50
Rb25 S1 Throttle body and throttle position sensor $60
Rb25 stock fuel rail with stock injectors $50
Rb25 injector loom $40
Wouldn't happen to have a decent condition rb30e harmonic balancer for r31 hanging around?
Rb30 head $100
Rb30 block $150
Rb25 S1 afm $50
R31 RB30 harmonic balancer are normally single piece while VL RB30 harmonic balancer are two piece as Shiv pictured. However I have seen two piece on a R31 before.
The Rb30 engine i have came out of a R31
Can you post up a pick of the side of the thing, if I can see if it has ribbed belts or v-belts it will give me a better idea (my rb30 has ribbed)
Looks similar to mine except mine is a single piece (and, um, has a massive chunk missing out of it):
rb30e%20harmonic%20balancer.jpg[/url]
rb30e%20harmonic%20balancer2.jpg[/url]
Anyone know if these would be interchangeable?
Edited by dorifticon
bump make an offer guys
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
