hmm If you still have them in a few weeks ill prob pick them up. Can't remember if its my rear or fronts that where running low... Ill have to wait till i get my car back to check haha
R32 passenger seat & rail, couple of marks, no rips or tears.
$50
Unkown driver's side bucket seat. Like an English backpacker; sunburnt pink, bottom mounted and rather dirty. Perfect for a track vehicle. $80.
Bride R32/R33 Type S driver's side rail. $150 (will fit the bucket seat with some flat bar used as mounting points, which I also have should you be interested in a package deal)
Complete 3 inch turbo back exhaust for a 33 gtst.
Bellmouth advance dump modified to fit a hotdog muffler in before the cat.
Dump pipe has been painted in high temp exhaust paint (supposedly has ceramic in it) and wrapped.
Cat is complete, not bashed out or "high flowed"
Single straight through box muffler before the rear subframe.
3 inch twin pipes or cannon out the back, both will be provided.
$300 neg.
3.5 inch cat back to suit 33
single hotdog muffler before rear subframe.
Cannon at the rear.
$150 firm.
Brand new fibre glass gtr style front bar to suit 33 gts/gtst
Sold the car before it was fitted.
No holes have been drilled yet.
$150 firm.
Pm, or Text me on Zero 415 055 80 Nine
Cheers,
Jono.
RB25det forsale.
Motor has 110xxxkms, complete with turbo, lines, intake plenum.
Doesnt come with ecu or loom but can for extra.
$2000ono
Edited by ScR33m3r
RSR's Gonski's
Thanks James - very nice 4 door and the exhaust note is awesome.
I heard you from Bonython all the way to the Monaro highway.
Thanks Richard.
Enjoyed the chat and looking over the Sinista R32.
Also, I here by, on scouts honour with 3 fingers raised I will not do skids on those nice tyres you sold me. :ph34r:
Cheers,
James
Thanks Richard.
Cheers,
James
So donuts are out of the question? :P
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
