I'm after a set of R34 GTT suspension, either stock or aftermarket.
I'm located in Sydney.
On another note, does anybody know if any of the other model suspension are interchangeable with the R34 GTT ones? (eg R34 GTR?)
Thanks!
Got front Shocks/Springs from a 114,000km R34 GTT Front Cut. Not sure on condition as never used, but hell $50 take em I want them gone as I'm tired of having leftovers sitting around.
