Hi Guys,
Just wanted to start doing this and its open for anyone that would like to experience what its like to be a passenger in an R35 GT-R, I have been blessed to have the opportunity to own one of these beautiful machines and previously (R34/R33 GT-R's).
Every Sunday morning I go to Church (Baptist Church), the Church starts at 10am-11:30am pretty much if your intertsted, I will have to confirm avaliablity but I will pick you up from your place or venue, we will drive to Church which is in North Brisbane (Chemside Area), and pretty much attend with me and I will drop you home afterwards.
Here are couple of points.
1. I don't want any money from you for my time or fuel, you just have to be willining to come to Church with me, its not a weird cult or anything about 300 people that are friendly and its relaxed.
2. Really only have room for 1 passenger in the front although dont mind taking a 2nd person to sit behind you, although it is squashy, would only really work if they were a small build.
3. It is preferable if you live or I can pick you up from a location that is within a 15km Radius from Chermside. If further still PM me and I can see what I can do.
4. Must be over 18 years of age if under 18 must be acompanied by an adult.
If you are intersted send me a PM on the site with your mobile phone and which Sunday suits you, I will PM you back to confirm no one else is booked in for that day.
This is not a scam or sales pitch and I DONT'T get paid for this or anything whatsoever even the church has no idea that I'm doing it so you will just be like me bringing a mate along to a service.
I am a fellow car enthusiast and a business man but church has played a big part in my life, I thought it would be great to allow people to have an opportunity to get to ride in the greatest GT-R to date,
I would appreciate only positive remarks I understand and respect other people believe other things and not in God at all and thats fine I'm not doing this to start a religious debate.
I merely just want to give people the opportunity to go for a ride and come to church.
Cheers,
Also I hope offering this isnt against forum rules, as its not for money or anything it's compeltely free.
Edited by R-PWR
https://www.sau.com.au/forums/topic/399804-free-r35-gt-r-ride/
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
