For sale
1999 MY00 WRX
Up for sale is my WRX, which I purchased as a bit of a project for myself - I wanted to get to the track a heap more with the WRX club of NSW, and wanted to build it strong so I could drive to the track, have a day full of laps, and drive home without having to worry too much about the car's reliability (i.e., get rid of all the MY00 gear!!!). Since June, I've been to the track exactly *zero* times!
However that won't be happening as my missus has started work in Canberra, and I will simply just not get the time to enjoy it and take it to the track! I'm in need of a car I can do bulk KMs in, and not worry about it not getting used like it should!
I purchased the car in June 2012, it had 192,000KMs on it.
At the time, the only mods it had was:
* JDM WRX RA Gearbox (4.44 ratio, great acceleration!)
* Anti lift kit
* King Springs
* Front and rear sways
* MY02 WRX wheels
Since I've had it, I've done a JDM 02 STI AVCS engine conversion on it, complete with 2002 STI loom so it has the STI ECU which you are able to do reflashes on, and keep stock drivability. The car now has 199,000KMs on it, however the engine has 55,000KMs on it.
The mods now are:
* JDM 2002 STI engine (EJ207, forged, AVCS, full 100,000KM service done on it - engine only has 55,000KMs)
* New Exedy 5 speed clutch (OEM)
* 2004 STI TMIC
* CBRD BBK turbo
* 3" PSR Turbo Inlet + SFB
* 3" Hitech turbo back exhaust
* KYB AGX adjustable suspension all round (put in 200KMs ago)
* H&R Springs (reds)
* Mongoose M60 Immobiliser / Alarm
* RDA Slotted rotors on the front (put in about 200KMs ago)
The mods list there, while only small, has added up to a fair bit of money - and has well and truly surpassed the my original purchase price of the car. There's a huge amount of labour in it, let alone the cost of parts. The price I'm offering the car at is more than some similar model cars, however you will be getting an excellent base of a car (with an impressive mod list), that has unreal performance, and massive potential - whether you drive as is, or put more money in to it! If you were to put more money in to it, the next port of call would be E85, bigger injectors and a retune.
As you can imagine, it goes very, very well. It has been tuned by Phatbotti tuning, at a quite safe 20PSI. Plenty of info / good stories on NASIOC.
The car has a minor issue, aircon needs a regas! It shouldn't be too hard for you to get an auto electrician to sort that out.
If you have any questions, feel free to ask away. I'm happy for serious buyers to come and inspect, I'm pretty flexible with that (work day shift). The price is firm, if it doesn't sell - I'll keep it - I still enjoy the car immensely, just cannot use it for what I originally intended to. Those who are seriously interested however, we can talk about the car & price, plus some other mods I have that I haven't gotten around to installing yet. This car suits a buyer who wants a serious GC8, with a great choice of mods!
I'm after $16,000.
Thanks for looking
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
