Big Dollars spent, has all the necessary equipment to perform and win - all you need to do is hit the start button and go racing. This car has been used for racing in street sprints and it has proven to be very low maintenance and reliable and it is a proven track record performer and first place and outright winner in competition.
With 600hp at the wheels and only 1200kg this car has a great power to weight ratio with awesome acceleration.
This vehicle has too much to list but will try...
* Engine
- 270 degree cams
- 1900 cc injectors
- Custom fuel rail
- Garret GT 35R turbo
- 4 inch inlet pipe & large K&N pod filter
- 6 boost exhaust manifold
- 50mm turbo smart pro waste gate
- 4 inch side exiting exhaust from turbo
- A system of 3 catch cars for oil surge that all
return to sump
- Alloy radiator
- Greddy large 100mm intercooler
- 2 large engine oil coolers & remote filter
- Twin Bosch O44 fuel pumps feeding each
end of fuel rail with twin 3/8 In fuel lines
- 20litre RCI fuel cell
- NPC twin plate clutch
* Body
- Carbon fibre bonnet
- Carbon fibre boot lid
- Carbon fibre GT T-Wing
- Fibreglass doors
- Fully welded in roll cage
* Handling and Brakes
- Grex 6 piston 355mm x 32mm front brakes
- Grex 4 piston 330mm rear brakes
- Hurst line locker
- Camber toe in castor adjustable arms front
- and toe & camber adjustable arms
rear
- Titanium front strut brace
- Nismo rear strut brace
* Wheels and Tyres
- Rays TE 37 rims 17x9 all round
- Dunlop uncut wet full slick, very soft
compound 265 wide - (New - barely used)
$29,990 neg
SORRY - Not interested in any swaps.
SERIOUS ENQUIRIES ONLY PLEASE - NO TIMEWASTERS OR TYRE KICKERS!!!!
IF YOU ARE GENUINELY INTERESTED PLEASE PHONE - have plenty of photos - please contact us with an e-mail address if you would like some more.
For any other questions - please contact me. 0408 737 677
    • Sounds like the solenoid might be cactus, if the solenoid trigger wire was still attached (and it was just the main power to the starter itself remove). Just to provoke Neil haunting me for the rest of my life... Have you tried tapping it with a hammer while someone switches the key to start? This might work for the fuel pump too... šŸ˜›
    • I need help dealing with an engineer who is massively overcharging me for an engineering report on my modified, written-off Jeep to get it roadworthy. šŸ”¹ Initially, he quoted me $3,500 - $4,500. šŸ”¹ First invoice: $5,315 (already above the quote). šŸ”¹ Second invoice: $1,375. šŸ”¹ Now, he has sent another invoice for $3,100! This is way more than double what I was originally quoted. I feel like Iā€™m being ripped off. Has anyone dealt with something like this before? What can I do? Any advice on how to report him or fight these unfair charges? Would really appreciate any guidance! šŸ™ Am in Adelaide.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
Ɨ
Ɨ
