Big Dollars spent, has all the necessary equipment to perform and win - all you need to do is hit the start button and go racing. This car has been used for racing in street sprints and it has proven to be very low maintenance and reliable and it is a proven track record performer and first place and outright winner in competition.
With 600hp at the wheels and only 1200kg this car has a great power to weight ratio with awesome acceleration.
This vehicle has too much to list but will try...
* Engine
- 270 degree cams
- 1900 cc injectors
- Custom fuel rail
- Garret GT 35R turbo
- 4 inch inlet pipe & large K&N pod filter
- 6 boost exhaust manifold
- 50mm turbo smart pro waste gate
- 4 inch side exiting exhaust from turbo
- A system of 3 catch cars for oil surge that all
return to sump
- Alloy radiator
- Greddy large 100mm intercooler
- 2 large engine oil coolers & remote filter
- Twin Bosch O44 fuel pumps feeding each
end of fuel rail with twin 3/8 In fuel lines
- 20litre RCI fuel cell
- NPC twin plate clutch
* Body
- Carbon fibre bonnet
- Carbon fibre boot lid
- Carbon fibre GT T-Wing
- Fibreglass doors
- Fully welded in roll cage
* Handling and Brakes
- Grex 6 piston 355mm x 32mm front brakes
- Grex 4 piston 330mm rear brakes
- Hurst line locker
- Camber toe in castor adjustable arms front
- and toe & camber adjustable arms
rear
- Titanium front strut brace
- Nismo rear strut brace
* Wheels and Tyres
- Rays TE 37 rims 17x9 all round
- Dunlop uncut wet full slick, very soft
compound 265 wide - (New - barely used)
$29,990 neg
SORRY - Not interested in any swaps.
SERIOUS ENQUIRIES ONLY PLEASE - NO TIMEWASTERS OR TYRE KICKERS!!!!
IF YOU ARE GENUINELY INTERESTED PLEASE PHONE - have plenty of photos - please contact us with an e-mail address if you would like some more.
For any other questions - please contact me. 0408 737 677
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
