quite often if you bend one piece of the suspension you bend everything (in that corner), i know someone did something similar in a r32 recently which pushed the chassis rail back about an inch aswell, ...is on the chassis machine next week
Change the two arms first , could be fine after that . Jeez , you all need to lighten up a little , if something is bent , you will know when you go to get a wheel alignment (which you will need to do when the parts have been replaced ) . If you can get a full steering rack , change the whole lot and buy new rack bushes , most imports i see need new rack bushes anyway and it makes the steering feel nicer.
Looks like the ol' understeer in to a curb trick. Replace lower control arm and rack end.
The chassis should be ok but not guaranteed, the castor rod bush even though not leaking it could be questionable
Edited by Dobz
