nicktherip Posted May 10, 2012 Share Posted May 10, 2012 hey guys, Going to buy a Transgo Shift Kit, iv'e heard alot of great things about this shift kit. im just seeing if anyone else is interested in a group buy? i will be going thru jetwreck who has done a ton of these kits. ive been quoted $275 not installed & will have to add postage to those not able to make it to sydney to pick up from jetwreck. please let me know by friday 18th may if you are interested,hopefully with enough guys we can get that price dropped. thank you nick Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/ Share on other sites More sharing options...
Vimana Posted May 10, 2012 Share Posted May 10, 2012 Whats involved in installation? Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6351967 Share on other sites More sharing options...
scotty nm35 Posted May 10, 2012 Share Posted May 10, 2012 Its fairly complicated as you need to remove the trans sump and valve body which have around a hundred bolts holding them in. They all need to go back together in the same hole too. Read the instructions when you get the kit and make the decision then, if it seems too complicated get Craig (jetwreck) to do it, or someone local if you aren't in Sydney. It will cost a lot more if you get it wrong... Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6352006 Share on other sites More sharing options...
slippylotion Posted May 10, 2012 Share Posted May 10, 2012 If your comfortable using spanners it's not that hard at all. One of the easier major upgrades ive done to any of my cars. When I did mine I found it to be quite easy. Just take your time, mark everything you remove and best to have a mate help out so you can double check everything you do. No special tricks involved, just read the instructions and it's nice and easy. Then you have the satisfaction that you did it yourself. Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6352022 Share on other sites More sharing options...
Vimana Posted May 10, 2012 Share Posted May 10, 2012 And what does it do for my car? Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6352072 Share on other sites More sharing options...
sheldon2369 Posted May 11, 2012 Share Posted May 11, 2012 A lot. You'll find yourself changing gears much quicker, and a lot more responsively and when you plant your foot the changes will be very sharp and you'll get a little chirp from 1 - 2, sometimes 2 - 3, but in the wet it's anything but a chirp. When your foots not planted its normal gear changes, but its a very noticable upgrade when you want it to be. Personally I wouldn't recommend installing it yourself. But i'd definitiy recommend getting one. Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6352221 Share on other sites More sharing options...
T4NK Posted May 11, 2012 Share Posted May 11, 2012 I had mine installed and a oil change with nissan matic J at my local auto shop for $300, cost me $100 labour to have it put in and i bought mine off ebays was $300 from the USA something like that, but once it was in i get wheel spin till i hit 3rd, it goes off, cherps the tyres all the way to 5th if ur nailing it to the redline on every gear shifts are really solid and fast, but one bad thing i noticed is down shifting, mine does not like it so much gives a noise sometimes (probs me shifting down at wrong times) but other then that its mint. Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6352443 Share on other sites More sharing options...
nicktherip Posted May 13, 2012 Author Share Posted May 13, 2012 im getting craig (jetwreck) to install mine would rather someone with alot of knowledge doing this than some local shop. im looking forward to meeting craig & getting some more tips on what i can do to improve performance.im also getting craig to do the uprev engine management on the V. Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6354370 Share on other sites More sharing options...
Magic Posted May 13, 2012 Share Posted May 13, 2012 (edited) I'm interested, although I'm in Perth. What comes in the kit? The Transgo website is hard to get around, but I think the Transgo Reprogramming Kit is what I need. Also if this kit is installed is it neccessary to upgrade the valve body al la MV Automotives? Edited May 13, 2012 by Magic Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6354963 Share on other sites More sharing options...
scotty nm35 Posted May 13, 2012 Share Posted May 13, 2012 The Transgo kit IS the valve body upgrade. It is just a few valves and springs to install into your stock valve body, no rocket science involved. Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6355085 Share on other sites More sharing options...
Magic Posted May 14, 2012 Share Posted May 14, 2012 Sweet put me tentatively down for now. There's a WA authorised distributor according to the Transgo website but their emails are bouncing back. I'll try calling them today to see if they have it in stock as it might be cheaper for me. I'll let you know tonight whether I'll grab one a part of the group buy or not. Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6355383 Share on other sites More sharing options...
V35_Paul Posted May 14, 2012 Share Posted May 14, 2012 Yeah put me down for one. I'll need posting to WA. Or if the WA authorised distributor is cheaper i'll go with them. Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6355452 Share on other sites More sharing options...
Magic Posted May 14, 2012 Share Posted May 14, 2012 What model kit is this group buy? I just got quoted $419 for the RE5R05A-HD2 from Drive line Autoparts, the WA distributor. Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6355464 Share on other sites More sharing options...
slippylotion Posted May 14, 2012 Share Posted May 14, 2012 For you WA guys you can buy it from Summit Racing in the US for $276.75US delivered to your door. Or anywhere in Oz for that matter. Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6355493 Share on other sites More sharing options...
T4NK Posted May 14, 2012 Share Posted May 14, 2012 im getting craig (jetwreck) to install mine would rather someone with alot of knowledge doing this than some local shop. im looking forward to meeting craig & getting some more tips on what i can do to improve performance.im also getting craig to do the uprev engine management on the V. Yeh the shop i had it done in is not just any mechanic, it was an auto transmission specialist all they do is service auto's and also the RE5 box thats in the V35 is also in a few other nissans so its not a 1 of a kind and they are in cars sold in AUS so they do have experence working with them. Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6355850 Share on other sites More sharing options...
nicktherip Posted May 14, 2012 Author Share Posted May 14, 2012 Sweet Magic. T4NK i wasnt reverring to your post about some local shop i was just saying in general about getting this kit fitted by expert hope the kit is running smooth for you,i cant wait to get it fitted. Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6355927 Share on other sites More sharing options...
Magic Posted May 14, 2012 Share Posted May 14, 2012 I'm normally pro-local buying, but my cars currently in the shop getting a few things done to it so I got it express posted from Summit. Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6356308 Share on other sites More sharing options...
nicktherip Posted May 19, 2012 Author Share Posted May 19, 2012 hey guys looks like im going it alone with jetwreck. will let you know how it goes soon. take care Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6362472 Share on other sites More sharing options...
jbenj Posted May 21, 2012 Share Posted May 21, 2012 (edited) hey, i spoke to Jetwreck about installing the kit, looks like you are not the only one Edited May 21, 2012 by jbenj Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6364043 Share on other sites More sharing options...
nicktherip Posted May 21, 2012 Author Share Posted May 21, 2012 cool sounds good. looking forward to sharing experience Link to comment https://www.sau.com.au/forums/topic/399840-transgo-shift-kit/#findComment-6365238 Share on other sites More sharing options...
