Hey all, clearing my garage.
Item 1: 2x Lenso D1R in 18x9 +32 offset.Tyres have about 60% tread left but with massive camber wear. Good for skidpans or track? lol
Its been sprayed black, though the paint has started to fade quite abit. Minor gutter rash here and there.
Price: $200
item 2: 10x Nismo long hub bolts (60mm) Part No: 4022 - RS045.
Google search shows these will fit the following:
- S14/S15 (Front)
- R32/R33/R34 (Front)
- G35 (Front/Rear)
These are brand new still in the plastic packaging.
Price: $80
Item 3: R34 GTT rear spoiler in white (QM1 Polar White). Missing one stand. In good condition with no scratches.
Price: $20
Item 4: Kakimoto Full Mega N1 muffler. Not sure what car it came off but should fit onto any car with a bit of cutting and welding. Has some loose bits inside
I believe the size is 3" piping with a 4-4.5" tip.
Price: $50
I will upload photos when I get a chance to take some
Located at Canley Vale. Can also be picked up from Hombush during weekdays.
Cheers,
David
https://www.sau.com.au/forums/topic/399841-clearing-garage/
  • 3 weeks later...
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
