Wonder if there is a difference between the two, because I hear definition Red Light or Red Light / Speed Camera? I'm new to driving in Australia.
Turned right on Warrigal Rd from Battersford Rd at the intersection with a sign saying RED LIGHT CAMERA AHEAD, then speed up past the car which turned left.
The camera is pointing along the Warrigal Rd, so I wonder if it is activated by people running Red Light along Warrigal Rd only or can also be aimed at people who turn from Battersford Rd and speed.
Not sure about all states, but in Queensland I am fairly sure they are 2 separate units, red light cameras are just that, no speed camera. Fixed speed cameras tend to be on sections of road where people often speed, not generally on interesections.
Add to that the many mobile speed cameras around.
Red Light is is for running red lights (it takes a photo when you first run it than another to see how far over you have gone/proceeding to go).
Speed Cameras are for speeding.
I think it was last year that QLD rolled out integration of both Red Light and Speed Light Cameras at traffic lights. Basically you speed through, get done for speeding and done for running a red light.
I'd say most of the redlight cameras in Vic also detect speeding. They've been replacing the old ones for a while now...
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
