  • Replies 49
Odd...? I noticed that the Racepace built GTTRKT RB28 vcam R34 and the Midori R34 both ran external drains to the drivers side sump from washer bottle mounted catch cans.
I suppose if you meant dedicated circuit though, very small restrictors could be used as revs are always up high which would ensure the head gets enough, but not too much oil. Such a restrictor might not be a good idea in a street car though. I believe it was Steve telling me that some of the racepace cars were using a 0.9mm restrictor. Is this what you meant?
Sorry I should clarify - no additional drain @ rear of the head. Factory drains on the cam covers --> catch cans of course. Return to sump or not, plenty of different setups around.
Some users on here have the additional rear drain, restrictors (unsure what size), catch cans and STILL have motors breathing heavily. So something is certainly up when others don't need any additional rear drains to keep things under control.
Dont use a standard sump with a high volume pump. It is a recipe for a blown motor.
+1
Which to me indicated that the rear drains are perhaps not as effective as soem make them out to be. Which is different from saying they are not useful.
So the question then is: What size oil restrictor is in the head of your motor?
From memory I think is was the 0.9 that was in the original build unless he changed it.
I think there was a lot of other factors for the improvement, 5 pounds less boost now runs 20 psi for 355 rwkw, shimed oil pump, standard cams back in that lowered the RPM, better built engine with a much better ring seal and tolerances and a few other little tricks. Just a much better package.
Never had a problem since, not even a drop of oil in the catch can.
There is the main culprit sorted for starters.
So how much tension? How measured on what (brand) rings?
Wiseco pistons and I assume rings so nothing special, more attention on machining getting the block and bores exactly right.
In short, I just spent the dosh and went to someone who had a long history in building and developing RB engines.
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
