  • Replies 49
Odd...? I noticed that the Racepace built GTTRKT RB28 vcam R34 and the Midori R34 both ran external drains to the drivers side sump from washer bottle mounted catch cans.
I suppose if you meant dedicated circuit though, very small restrictors could be used as revs are always up high which would ensure the head gets enough, but not too much oil. Such a restrictor might not be a good idea in a street car though. I believe it was Steve telling me that some of the racepace cars were using a 0.9mm restrictor. Is this what you meant?
Sorry I should clarify - no additional drain @ rear of the head. Factory drains on the cam covers --> catch cans of course. Return to sump or not, plenty of different setups around.
Some users on here have the additional rear drain, restrictors (unsure what size), catch cans and STILL have motors breathing heavily. So something is certainly up when others don't need any additional rear drains to keep things under control.
Dont use a standard sump with a high volume pump. It is a recipe for a blown motor.
+1
Which to me indicated that the rear drains are perhaps not as effective as soem make them out to be. Which is different from saying they are not useful.
So the question then is: What size oil restrictor is in the head of your motor?
From memory I think is was the 0.9 that was in the original build unless he changed it.
I think there was a lot of other factors for the improvement, 5 pounds less boost now runs 20 psi for 355 rwkw, shimed oil pump, standard cams back in that lowered the RPM, better built engine with a much better ring seal and tolerances and a few other little tricks. Just a much better package.
Never had a problem since, not even a drop of oil in the catch can.
There is the main culprit sorted for starters.
So how much tension? How measured on what (brand) rings?
Wiseco pistons and I assume rings so nothing special, more attention on machining getting the block and bores exactly right.
In short, I just spent the dosh and went to someone who had a long history in building and developing RB engines.
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
