Hi there, this is my firs post so be nice! This is my first skyline I purchased a couple of nights ago, r33 gtst series 1, 5 speed. There are a couple of noises which it has and a couple of issues, they may be related they may not. I have done a search and found a little bit of info but nothing that is identical to my problems.
Issue 1: In every gear between about 1500-3000rpm there is a vibration/grinding sound. As soon as you start to hear the turbo spool up it is gone, I have never owned a turbo so im not too familiar with their sounds if they are shot. It isnt blowing any white smoke. Could be a clutch issue, not sure of the age of the clutch but it engages very low on the pedal which indicates it is newish?
Issue 2: before i start the engine, but with the ignition on there is an unpleasant deep whine sound coming from the fuel tank, from inside the car it sound like an aerial going up. My first instinct was fuel pump, which i believe it is, but then when i listened right next to the fuel pump it sounded as a fuel pump should, a nice consistent quiet electronic whine sound. Is it normal for the fuel pump to be this loud? can also hear it over the engine under low revs. Or could this be a different issue?
issue 3: under full acceleration between about 4000-6000rpm in second gear (accelerates too quick in first to notice, havent got that high in 3rd or beyond) there is a pretty noticable flatspot. I have no idea if this is a fuel delivery issue or a turbo issue. Engine sounds fine, not like it is missing, but just has no pull in this rev range, before and AFTER up to 7000rpm it pulls hard.
these are all issues which I didnt notice during the test drive as I am not familiar with these engines, but on the hour drive home after getting accustomed to it these issues were noticed.
Any help would be very much appreciated!!
https://www.sau.com.au/forums/topic/399888-few-problems-with-new-r33/
issue 2 is normal, fuel pump priming, the reason you didnt hear it again later was the system was already primed from before
issue 1 / 3, ill let others who know more bout gtst explain
btw: welcome to SAU
Edited by BWRGTR
When i listened to it close up in the boot i got my friend to turn on the ignition so i could hear it priming, so it was definitely priming when i listened, where is the actual pump located? because i listened to the top where it is installed but is that where the pumping is done? I know what a priming fuel pump sounds like normally, this was much louder and more "unhealthy" sounding lol It may just be what the fuel pump in skylines are like.
Big aftermarket fuel pumps as used in Skylines can be enormously noisy. You need to get someone who knows what a big Bosch or Walbro pump sounds like to give an opinion.
Low clutch pedal is not a good sign. Possibly needs bleeding, possibly needs pedal freeplay adjustment.
Flat spot could be low fuel pressure. Could be too much boost (and so the engine computer pulls out timing and adds fuel to protect the motor - it's called rich and retard amongst Skyline retards, or R&R). What boost is it running? What other mods does it have?
The vibration / grinding noise is from the gearbox - though I am not sure why. I had my car converted to a manual - using an R33 GTST gearbox with 80,000km on it. Had a new HD clutch thrown in at the same and it has always made a grinding noise at low revs when you put any load at all through the box. On mine it disappears by around 2000rpm.
I don't know the true reason - some say it is worn bearings and others say it can happen after a HD clutch has been fitted. All I know is the gearbox is still working fine 3 years later. The sound is still the same, hasn't gotten any worse.
Edited by R34mac
hmm, ill have to look closely next time i'm not quite sure if it gets to 7, I just know it doesnt go over. How accurate is the stock one? There is an aftermarket one installed but the previous owner didnt actually connect it lol so ill have to get on that this weekend and ill see what boost im getting then.
A lot of people bag the stock guage as being completely shit. But the one in my car is 100% correct, and has been over the last 13 years. You mileage may vary though.
Don't necessarily trust the aftermarket one unless its reading matches the stocker's. It is unlikely that 2 different guages have the same error, so if they read the same, they're probably accurate.
issue one, sounds like the input bearing (or whichever it is) on the clutch, mine does the same thing. (may need replacing, may not)
issue two, new fuel pump is in order unless its an aftermarket one.
issue three, sounds like your boost is to high, if the boost is to high it runs rich in the mid range. mine does the same over 9psi.
Edited by ClutchBurndout-:(
yea mine does the same thing, im 90% sure its the one of the bearings on the fork/clutch. theyre usualy changed when the clutch is changed, so maybe a sign that the clutch is getting old? how is it to drive? no slipping?
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
