something wrong when trying to hold full boost
Guest | hype^ |
i just got a intercooler and upped the boost with a T-piece
im running 12 but i noticed it spikes to about 14 sometimes.
now my prob is when driving fast (racing or whateva) and i try to floor is and hold max boost past 3-4K the car it starts to go crazy..
it feels like its missing or hitting a limiter (fuel??) the car just start jolting really hard ..
its crazy..
whatcha'z recon??
Dyno testing won't replicate real world driving loads.
If you don't believe me, turn down the boost and see if it still does it. Then turn it up again, and floor it again. And then turn down the boost and floor it... And then turn up the boost and floor it...
Repeat as many times as it takes until you realise that I'm right :D
oh and turbosmart do a fuel cut defender in a valve and electronic type for around $100-180 and im not sure if it is a good thing/safe to use but you could also put on a air/fuel ratio meter to keep an eye on so that you know if it leans out.
oh and its good to hear your cars back on the road and i cant wait to see that front bar with a nice fat cooler in it :D
Ash.
Guest | hype^ |
lol merli..
thanx for the tips..
u too ash
i just went for a drive with my old man..
it definatly looks to me (who doenst really know much but anyway) like its boost cut..
when it spikes to about 13-14psi the car jolts and the boost drops down to whateva. if u keep accelerating itll go back up to 14 and jolt again.. so on and so forth..
stupid cars!!
I have experienced similar. As Merli said its the standard ECU overboost protection, which is not such a bad thing as you don't REALLY want to run a stock R33 turbo at 14-16PSI unless you are looking for a good excuse to buy a new one.
If you want to stop it doing this either turn down the boost, get a boost cut defender or buy a PFC as Merli said.
I've got the same problem, engine runs smooth until you hit full boost, at which point it goes really shuddery. Got mine tuned by Mark as well, need to take it back and get it adjusted.
Was wondering what it was, if it's just the boost cut i'll be a happy boy.
Matt
Hey hype didnt merli have a power fc he wanted to part with :);)
hehe go the full hog mate :uh-huh:
Yeah i hope to be back on road soon but i find out today if i get my new paint or not and if i do car will be stripped down tomorrow and if not the new ignition will be put in and lights sorted.
I also have a truck turbo on its way up from melb :uh-huh: so i got some stupid ideas of what to do with it.
Ash.
I didn't suggest the PowerFC because I'm selling one. I suggested it because it's the easiest and best solution to your problem.
I ran 0.9 bar boost (14psi) on my R33 GTS-t for about 8 months, and it didn't miss a beat.
Anything over 10psi, and the standard ECU starts to retard timing and you get a huge hole in your power curve.
Anythin over 14psi, and the ECU will cut fuel, making your car seem like it just hit a brick wall for a second. That's the overboost protection you're experiencing.
The PowerFC fixes both the retarded timing and overboost protection problems that you are facing.
Here's a dyno chart of my car on standard boost, and then when I tried to dial in 0.9 bar... This wasn't the boost cut, it still pulled smoothly, but you can see where the ECU goes "OH SH1T... too much boost" and retards the timing:
Here's a dyno chart of the car's power after I put the PowerFC in. No other mods since the previous dyno graph I posted above.
merli i knew you wanted to sell it so i just gave the hint to hype to help fix his prob and give him more power dont think im telling him to buy cause you said what you said and because you have one for sale it doesnt really worry me who you sell it to but im sure he wouldnt mind one after spending what he did and to have this prob pop up (which cant be helped at that boost) so if he could get a 2nd hand power fc for a good price (and we know your a good guy and look after your stuff) that will make him happy once more :)
In the end i just wanted to say to hype that you had one for sale merli because it would be worth it for him to get one.
Ash.
Ash.
HAHAHAHA... That has to be the world's longest sentence ;)
/me gives Ash a few periods and commas :)
No worries dude... I was just emphasising that this is honest information, not some ploy to sell my PowerFC.
Running a completely stock engine, and i do mean completely stock as in standard intercooler, turbo, the lot, the only aftermarket stuff was a blitz BOV and an Apexi F-Manage piggyback ECU running at .85 bar i was able to get 252HP at the wheels... That was at a dyno day, but i did get it dyno'd ages before that and got 245HP at the rears...
If you wanna see a better quality picture just go to my website then look under dyno...
Alan.
Guest | hype^ |
well i turned down the boost tonight...
i think what happened is when the boost was being set it was a really hot day.. so when set it was boosting properly to what it was ment to (12psi)...
but when after i let it cool down and took it out in the cool night air it was goin beyond what it was set at .. (to 14psi)
would i be right in assuming this??? :D
so my old man and i went out tonight and set it back to 12psi on the nice cool night air.. not shes running properly.. its hold 12 all the was to redline.. MUCH unlike b4 :D
Be carefull with your fuel pump.
Providing you fuel pump is not leaning out and already providing good power (its almost dead):
Buy a std generic bleed valve and a check valve which is like a one way valve.
Hook it up to your fuel pressure reg with the check valve obviously between the plenium and the bleeder.
THEN.... slap it on a dyno for approx $140
Tune the Bleeder and the Boost/Timing and get around 170rwkw.
If you fuel pump is crapping its self well you will already be making close to that power level.
Remember some dyno's read different lower/higher.
The figure of 170rwkw is going from two DD dyno's here in SA.
Tilbrooks and RPM In Adelaide.
Both of their Dyno's read very very close.
Some others read higher a lot higher.
    • Splitfire Nissan RB Twin Cam Street Series Splitfire Coils. Basically brand new less than 10kms use. Only selling as ive upgraded to the IGN-35A coils $400 price pretty firm
    • We have 2x Swifts and my plans for a Swift, unfortunately, do not extend to an intake and an exhaust. I've been having dirty thoughts about a 2.5L Suzi V6, AWD gearbag out of a suitable donor, rear floorpan graft to take the rear cradle from same, and either trumpets of evil or a small supercharger. If I'm going to make noise in a Swift, I want it to be anti-social, evil handling and rough. Probably need to be fully stripped inside, matt black paint, plastic windows, 7" wide wheels, big brakes, silly suspension, etc etc etc. I have no idea if any of the proposed driveline components could take the pain. But it would be a hoot finding out.
    • Really, anyone modifying a car isn't being financially smart. We're doing it for the things we love. And honestly, a high revving, light, NA car is actually pretty darn fun. I used to have a Swift Sport, and I miss that thing as a daily, and yes, doing something like some intake and exhaust stuff would have made minimal gains, but would have bought an even bigger smile
    • We are taking pricing back to 2022! The skid pan is nearly double the size of avalon so much better for longer battle runs as seen here > https://www.youtube.com/watch?v=ANxdRf3Do2s When: Saturday 14th June 2025 Where: Winton Skid Pan (Winton Motor Raceway) Price: $145 for SAU VIC Members            $199 for non Members Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to motorsport@sauvic.com.au or print and hand in and Driver Sign In. email motorsport@sauvic.com.au To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and it is reccommended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs on the enty link. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Accommodation:  In an effort to try new things and support other country towns we thought a new location for accommodation was worth trying and Euroa was great last time plus its 30 minutes closer to Melbourne. Saturday night we will book a spot at the pub for a couple of quiet drinks.......   Book your accommodation ASAP before it sells out, there are also other options in town if you want to stay elsewhere and join us for dinner Saturday night.   https://euroacaravanpark.com.au/ Address: 73-103 Kirkland Ave, Euroa VIC 3666 Phone: (03) 5795 2160 Entry link with Full Supp Regs to read: https://www.sauvic.com.au/entry/deca/20250614 Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email motorsport@sauvic.com.au Entry List: 1. Josh M 2. Anna 3. Luke  4. Katie 5. Martin 6. Tony 7. Alix 8.  9.  10.  11.  12.  13.  14.  15. 16.  17.  18. 19. 20. 21. 22. 23. 24. 25. 26. Reserve List 1. 2.
