Hi All,
Had an issue with my GTR last night.
Engine had a noticable miss while driving at approx 60km/h and then a few minutes later when I was stopped at the lights, I went to take off normally but the car was constantly bunny hopping and stalling and wouldnt actually drive more than a metre without sh*tting itself.
I could free rev it but as soon as i took my foot up off the clutch to take off it would stall or almost stall. Tried quite a few times.
I managed to limp it to the side of the road and then jiggled the rear AFM cable and the AFM itself as a first attempt to rectify and the car appeared to instantly start idling smoother and i could drive it again. But I dont know if this was just coincidence though.
Is there anything else I should be checking? It probably is the AFM or dirty AFM connection / plug - But what else could cause this behaviour?
The car used to have a different constant miss and lack of power which was caused by a worn out intake manifold gasket but this has since been rectified and is something different.
Previously, the car has had -
- Test for air leaks performed
- Replacement metal intake manifold gasket and hoses
- Replacement NGK Platinum PFR6A-11 plugs
- Coil packs checked - appear okay
- Rear air flow meter replaced (as previous air flow meter had a higher voltage and was causing the car to run a bit rich)
- Fuel filter replaced with Genuine Nissan - 16400-53J10
Doubt it would be a clutch issue but incase it helps diagnose, the car has also recently had -
- Stock dual mass flywheel reinstalled with Nismo clutch remaining in the car
- Replacement spiggot and thrust bearing
- Brake and clutch fluid topped up with Castrol Response Super DOT 4
Only things I did yesterday morning was put in Royal Purple HPS 10W40, replaced the oil filter with a genuine Nissan 15208-53J0A and also put some fuel injector cleaner into the fuel tank.
Will be aiming to get it to my mechanic tomorrow, but may be hard to reproduce the fault.
Any advice or info would be appreciated.
Cheers.
Edited by iwanta34gtr
sounds like afm bud. Also check you intercooler hoses for splits and cracks. The stock ones on mine developed a crack in them, but I also had a AFM die aswell.
Thanks mate, I will take a look at the cooler hoses - but I also have a gut feeling its the rear AFM fouling up again.
Fuel filter?
Thanks for the reply mate, but I have already changed the fuel filter with a genuine Nissan 16400-53J10 item.
Still appreciate your post and trying to help anyway.
Just had this happen on mine, was my lower AFM. I had the same thing with sputtering and bunnyhopping. I found that unplugging both afms should make the car idle a bit high but smoothly and plugging the AFM's back in should cause the problem to reappear.
I tried some AFM cleaner from supercheap but it didn't fix mine, contact cleaner should work as well.
Thanks guys. As the rear (top) AFM was a replacement from my mechanic, will be aiming to go back and get diagnosed / replacement today.
Also need to get the front AFM checked.
Will post results.
Update.
Took the car to my mechanic this afternoon and it spat out an air flow meter error code.
Replaced the rear air flow meter and cleaned the front one while we were at it - so far so good, touch wood.
Will see how it goes over the next few days.
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
