Hi I recently sold my R32 GTR project car and have a fair few bits left over that I would like to clear out to get some cash back
Hi Octane RB30 / RB26 sump adaptor - good condition, only test fitted - $600
RB30 Built Bottom end - Arias Forged Pistons, H - Beam conrods, JUN crank collar, Tomei Oil pump, ACL race series bearings, Tomei oil restrictor - $4000
RB30 Hi capacity Baffled Sump - $300
RB26 Gearbox - good condition - $600
S13 SR20det gearbox - good condition - $550
RB26 Head, fully reconditioned, basically brand new - HKS 264 / 272 cams, titanium valve guides, HKS springs - $2200 (still sitting at machine shop)
RB26 sump + diff - $150
S14 rear bar - $50
FC RX7 rear bar - $50
SARD 800cc RB26 injectors - $600
R32 GTR Power FC and hand controller - $1000
Items Pick up only
Dan 0413761305
Located in Cheltenham SA
Edited by DemsA31
https://www.sau.com.au/forums/topic/399994-garage-clearout/
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
