1983 Nissan Datsun Skyline - Whats It Worth?
Hi Guys,
I am selling my Grandma's car and have no idea what it is worth.
It is a 1983 Nissan Datsun Skyline
24 6 Cylinder
Auto
151,000 K's
10 months rego
1 owner with original papers
Edited by HIRISK
My goodness that thing's clean.
Being an L24E it might be desirable to someone if only for the engine.
I'm trying to picture it hotted up, ie. big wheels, lowered, colour coded and a decent huffer pumping air into the the motor, but just can't see it which is a shame because it looks unbelievably straight.
If there's no rust and paint is great I'd push for a bit over 2k..Maybe 2.5k with rwc. That front end is gorgeous, Little features like the headlight covers and rim trim rings add to appeal. This is one MR30 that should stay original and be cared for.
Hey guys, now is the time to get on these.
CH plate eligible a cheap reliable classic.
Im going to say if it was Manual,
I would buy it tonight
Just had a chat with Dad as I have not looked at the car in a while.
Apparently...
- No rust
- Never been in an accident
- Motor is original and un-opened
- My Grandparents bought it brand new in 1983 and have owned it ever since
- Has been well maintained
I am going to go and have a look properluy on the weekend to get a good feel for where it is at.
The more I look at it the more I tend to agree with Socrates.. dash, cluster surround and steering wheel look brand new. This is in the upper echelon of original MR30's, of which there are very few left.
2k is around the right price there's a couple in tassie for sale for around 1500 same km and same nic
pitty she is auto but if u were in tassie i would buy it
Getting a RWC will definitely add value to the car. At a guess this is one of the rare examples where the money you invest in the RWC will be more than recovered in the sale price. Have a mechanic do a pre RWC inspection and give you a list - if there are any, of the things that need to be fixed before he signs the certificate.
A bit of polish and Amour All and that engine bay would look a million dollars, too.
  • 3 weeks later...
You know that Vic Roads has dramatically reduced the requirements for what constitutes a roadworthy windscreen? Now a windscreen is only unroadworthy if it has a star +16mm in the area covered by the wipers, a crack +150mm covered by the wipers or is so generally badly damaged, scratched or discoloured you can't see out of it.
http://www.vicroads.vic.gov.au/NR/rdonlyres/7A14DDDC-3DF3-4ADD-9821-B8C7816777A3/0/VSI26web.pdf
Most mechanics ignore the Vicroads requirements and still pick the windscreen over damage outside the area covered by the wipers, or insignificant marks that do not impair the visibility of the road. This is very irritating.
Good luck with your sale at any rate.
 Share
    • Well I had 2 choices from then on. I either had to (reluctantly) move it on to another potential buyer and take the loss on the chin. Or I stick with it and turn it into a restoration project. I chose the latter. Project Snowstorm began! The frp body kit was the first thing to go. Turns out the original colour used to be silver. The Neo and gearbox were removed, along with the prop and exhaust system before it took a trip to the bodyshop, where I wouldn’t see it again for quite some time due to the pandemic hitting very soon after they took it away. Eventually, progress began and damage assessments made. Even the front chassis leg was in pretty bad shape!     Then the chopping commenced. For these guys it was just usual routine, to me it looked absolutely terrifying!   More to follow as I’m struggling to focus on my screen at 12:45 am!!!
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
