I have some prices back for the mat sets, there are quite a few options but this will give you an idea what they will charge. I think its great this company was willing to customise mat sets for us, lets make it worth their while.
Standard loop or plush carpet in various colors:
2 front mats: $75
4 floor mats: $85
Full set including hump mat with velcro: $95
Cargo mat: $80
USA quality plush carpet, soft feel, only 4 colors:
2 front mats: $95
4 floor mats: $125
Full set including hump mat with velcro: $145
Cargo Mat: $100
I will try to get some decent pics when its not raining but the fit is perfect and the feel of the USA plush carpet is amazing. Very happy with the result, the Grey I chose is nearly the same shade of the stock Grey carpet, even though the pics show differently.
They cut squares out for the luggage hooks in the back, hopefully it sits well with the hook over the mat, you can ask for the hole or leave it underneath, your call.
Contact All Car Carpets on 1800 227 628 and tell them Scott with the white Stagea gave you the number. :)
http://www.all-car-carpets.com.au/
https://www.sau.com.au/forums/topic/400083-m35-carpet-mats/
That looks like a good deal they've put together.
I got a full set from Japan over a year ago & other than the back seat mats clipping onto the centre hump mat via studs, they are pretty well the same as what you have.
Of course by the time I paid the freight they were a lot more expensive than buying local. I should have anticipated this....
https://www.sau.com.au/forums/topic/400083-m35-carpet-mats/#findComment-6355740
Have you tried that Dynamat stuff Scotty? They do a floor material that's supposed to be pretty good.
Thanks for the ground work on the floor mats. Cheaper than the Nismos that were looking like my only option. My mats are actually in good nick, bar the drivers which is ruined. Cargo mat would be good too!
https://www.sau.com.au/forums/topic/400083-m35-carpet-mats/#findComment-6357559
Hell yeah! Nice work Scott.
The only small change I would love would be to have the cargo mat to cover the back of the rear seats too. I am constntly loading stuff in and out of mine and it would be handy.
Will give them a shout tomorrow.
https://www.sau.com.au/forums/topic/400083-m35-carpet-mats/#findComment-6358913
    • Sounds like the solenoid might be cactus, if the solenoid trigger wire was still attached (and it was just the main power to the starter itself remove). Just to provoke Neil haunting me for the rest of my life... Have you tried tapping it with a hammer while someone switches the key to start? This might work for the fuel pump too... šŸ˜›
    • I need help dealing with an engineer who is massively overcharging me for an engineering report on my modified, written-off Jeep to get it roadworthy. šŸ”¹ Initially, he quoted me $3,500 - $4,500. šŸ”¹ First invoice: $5,315 (already above the quote). šŸ”¹ Second invoice: $1,375. šŸ”¹ Now, he has sent another invoice for $3,100! This is way more than double what I was originally quoted. I feel like Iā€™m being ripped off. Has anyone dealt with something like this before? What can I do? Any advice on how to report him or fight these unfair charges? Would really appreciate any guidance! šŸ™ Am in Adelaide.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
Ɨ
Ɨ
