  • Replies 104
Oh hey guise :action-smiley-069:
Just a suggestion but the tuner could have set rev limit to hard cut at 2000 which would have made it easier to diagnose
They may have done this, I'm not sure how they found it in the end, I went in to give them a hand on Friday and they had already found the problem and sorted it out. Just kept me in the dark about it, they must like suspense almost as much as me ;)
I'll post pictures hopefully later today guys, pictures are worth a thousand words...
Well... Sort of. Not really. I can't for the life of me understand what happened. I certainly didn't do it. But I can't see how my workshop would have done it either.
Will make more sense when I post photos. Which I can't do yet because I haven't got the car back yet :glare:
Explain the hole. Could this have damaged a valve or stick a valve open?
Possibly, I imagine when you shatter a cast alloy manifold like that there will be some debris. But I don't know which cylinder the valve problem is on, if it is only cylinder 1 then I imagine the shattered manifold was the cause.
I'm just waiting for my tuner to add up how much I owe them and then I'm going in to get the car home, so I'll post photos in a few hours.
IE could it have created debris that the motor could have ingested on its maiden limiter bash?
Again, quite possible. Thing is, I would expect that shards of cast alloy getting stuck in the valve guides would cause more of a permanent problem than just on full load power runs, ie. bent valves?
Edited by Hanaldo
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
