Hey Guys,
ok so im fairly new to skylines, i hav and r33 with an rb25det.
It has recently started to act wierd under acceleration but not all the time and not all the way through the rev range.
So for example if i pull away from the lights quicker than normal but not flat out, first gear ok change into second it will be ok as i got up the revs the all of a sudden it will stop accelerating almost like its bogging down, foot will still be down on accelerator but nothing happening. so il clutch down and blip it a few times to clear it up then its ok, then change into third and it will do it again at roughly the same rpm????
But it does not do it all the time, maybe half the time. Im not confident but i was thinking maybe running lean or rich at this point just to a fuel/air sensor or an air volume sensor??
Is this common and specific things to check or clean??
The engine is completely stock apart from a HKS pod filter and a turbo back exhaust, which were both on the car when i bought it 2 months ago.
Greatfull for any info advice or solutions cheers :yes:
https://www.sau.com.au/forums/topic/400099-bogging-down-under-acceleration/
What kind of boost are you running?
Do you know what rpm it does it at.
When it happens do the revs keep climbing or do they bog down much like the car does.
Could be clutch slip
Could be R&R rich and retarded from running to much boost.
Also could be misfiring
so dry joints on these plugs is a common issue??
It sounds and feels to me like it could well be this or something very similar. Unfortunatly i dont know anybody else near me with a skyline.
But i may try cleaning and re inserting all the plugs??
I have not had any kind of engine warning lights come on, would a sensor issue not trigger this? ie if the afm sensor is playing around with the mixture would the exhaust egr sensor not read faulty??
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
