All brand new parts in original unopened packaging up for sale. Best/cheapest mods for your V35 in my opinion.
No longer need them since I'm selling the car :(
OEM 350Z Z-tube (Stock V35 intake tube is restrictive) $140
http://www.ebay.com.au/itm/GENUINE-NISSAN-350Z-Z33-Z-TUBE-INFINITI-G35-OEM-NEW-/190618619853?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c61c14fcd#ht_875wt_1161
Motordyne Plenum Spacer 5/16 Basic for Coupe 03-07, Sedan 03-06 (This in combination with above gives noticeable gain in performance, +13hp I believe) $220
http://www.ebay.com.au/itm/MOTORDYNE-PLENUM-SPACER-5-16-BASIC-G35-LANYARD-/160704553322?pt=Motors_Car_Truck_Parts_Accessories&hash=item256abce16a#ht_1175wt_1161
Tein S.Tech Lowering Springs Coupe 03-07 (Drops 1.2"/0.9" front and rear) $250
http://www.ebay.com.au/itm/280707835178?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_1069wt_1161
G35 Black License Plate $30
http://www.ebay.com.au/itm/270919761265?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_2049wt_1394
I bought them all from the States and all recently arrived
Message me if interested,
Thanks guys
Alric, these are the cars it fits mate, substitute G35 for V35 equivalent
Nissan 350Z (Z33)-2003 2004 2005 2006
INFINITI G35 Coupe (CV35) - 2003, 2004, 2005, 2006, 2007
INFINITI G35 Sedan (V35) - 2003, 2004, 2005, 2006
INFINITI M35 Sedan (Y50) - 2006, 2007,
INFINITI FX35 (S50)
Regarding the spacer/Ztube
eBay says it should arrive by today the latest, posted on 10th May, I have contacted the seller and will get in touch with you as soon as I receive it
Sorry fellas, out of my control
Just an update
STILL NOTHING! Have contacted the seller (Westcovina, power seller) and unfortunately the tracking stops when it leaves US.
Will keep y'all posted for when the spacer / tube arrives
Sorry
    • The fact that Hypergear has been posting here for like 10+ years would 100% make me go to him for a turbo upgrade. Glad you got what you wanted from them.
    • I second this motion. GTSBoy you need to start posting vids man.
    • Yep that sounds like a scam. Avoid that company if you can.
    • Mate. Your car is like 20 years old. Expect that the rubber bits (seals, hoses, etc.) needs to be replaced. Best bet is to carefully go through your engine bay and try to find parts that need replacing (e.g. rubber hoses). for your power steering issue, best bet is to pull off the pump (not that hard, you can buy basic tools from Supercheap et. al. to remove it) and then inspect/get it rebuilt. *edit* forgot to add, no idea on R34, but my R32 HICAS computer has been playing up since I bought it (10+ years ago), so I just disconnected the small plug to "disable" HICAS but keep my power steering. So something extra for you to look into.
    • Something to keep in mind, RB26DETT was dreamt up in 1986-1987 for the Group A regulations. So to compare it to a post-2005 engine is not the best. You must Compare the RB26DETT to its contemporaries, like the YB (which it killed off), the 1GG, 1JZ, whatever 5L V8 Ford/Holden had, etc. etc. aka late 1980's tech. When you're trying to match RB26 to a S58, you've gone off the deep end already and are looking at custom block/head/etc so no longer a standard engine. Technology has come a long way from 1990 to 2020.
