Hi guys. A mate told me to start this build thread so i did
Make: Nissan
Model: Skyline R33 S2
Year: 1996
Manual: yes
Engine: RB25DE
i have had my R33 for about 12 months now. i got it stock as a rock noting done to it and it was clean as. jsut what i wanted
I'm slowly building it up adding new mods making it how I want it to be.
So far these things have been done:
  • Xtream heavy duty cluth
  • Walbro Fule pump 255L
  • Front end resprayed + new bonnet. as i hit a kangaroo on the frist week of getting it sad.png
  • got some cheep Lenzos of a mate not the best but where only $400
  • New head unit and spekers installed
  • Front and back strut braces
  • new brake pads
  • High flow cat
  • HIDS
  • blue dash lights
  • Nardi steering wheel
  • Hurricance Extractors
  • coilovers HSD
  • Nistune ecu
  • front camber kit
  • camtech cams 260*
  • timming belt
  • water pump
  • rocker cover gasket
  • new plugs
  • and a dyno tuned. before all work was done it had. 110KW im still waiting for the cams to be finished. so it hasent had a final dyno but will let yous no.
  • 17x9 D1rs or drift techs not sure. (mattblack)
  • rear camber kit
  • bride bucket seats
  • brake/rotor upgrade kit
  • maybe a new body kit and black bonnet to match rims.
  • sway bars (whiteline)
so yeah guys tell me what yous think ill keep it updated and try get some photos up today smile.png
https://www.sau.com.au/forums/topic/400112-r33-skyline-build/
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
