ENTRIES OPEN,
LOCATION = EASTERN CREEK WET PAN
TIME TABLE
7:00AM GATES OPEN
7:30AM SCRUTINEERING
8:00AM DRIVER SIGN ON
8:45AM DRIVER BRIEFING
9:00AM START TRACK ACTIVITY
10:30PM END TRACK ACTIVITY
SPECTATOR
everybody is welcome to spectate at our events entry is FREE
we have an associate membership package available for spectators
costs $50 you get t-shirt, sticker, membership card and a free drink at all our events
you can apply for this on the day
SCRUTINEERING
your car will need to pass scrutineering
brakes, brake lights, seatbelts/harnesses, windscreen wipers and headights all need to work properly
drivers seat must be secured properly all wheel nuts must be present
you will need a secondary bonnet restraint if you dont have one just bring a short rope & the
scrutineer will assist you installing it
DRIVER/TRAINEE
to drive you will need appropriate clothing (non flamable)
your clothes must cover you from neck to wrists to ankles
closed shoes must be worn
and only helmets with the AS1698 sticker affixed can be used
COST FOR MEMBERS
$130 per person if your a member with driftmob and have a cams license
COST FOR NON MEMBERS
$150 per person if your not a member with driftmob and have a cams license
PASSENGERS/TRAINEES
$50
same clothing requirements as a driver, you can ride in any car of your choice
CAMS RELATED and COST
we can issue you with a cams license on the day
$57 yearly L2NS you will need to purchase club membership
$45 days L2NS no need to purchase club membership
please take note that to be able to hold a yearly cams license you need need to be a member of a cams affiliated car club ,keep in mind it usually takes 4-6 weeks from when you fill your application for cams to process and send out your license
for driftmob membership information read on
DRIFTMOB MEMBERSHIP
if you want to become a member you can apply on the day
$50 for an associate membership incudes a t-shirt and membership card
$125 for a full membership includes long sleeve shirt, membership card and stickers
$175 for a full membership includes long sleeve shirt, membership card, stickers and yearly L2NS
$85 for full membership yearly renewal
for more information visit http://www.driftmob.com.au
HOW TO PAY
entrants can pay on the day but we recommend prepaying to secure a spot
at this stage we can accept cash and eftpos if you want to pay on the day
we also accept over the phone credit card payment call 0406 669 635 (5pm-9pm)
PREPAY
deposit total amount and bring your reciept with you on the day
no prepayments after tuesday 19th JUNE
ACCOUNT NAME = DRIFTMOB INC
ACCOUNT NUMBER =259589
BSB =032372
BANK =WESTPAC
RUNDOWN
passengers/trainees are permitted at this event no roll cage nessesary
we are track time orientated this means we will not stop for lunch
car entries will be capped at 40 cars
for more information on DRIFTMOB CAR CLUB visit http://www.driftmob.com.au
if you have any questions please ask here ,
email us [email protected]or call 0406 669 635 (9am-9pm)
the driftmob crew..
https://www.sau.com.au/forums/topic/400117-drift-marathon-wet-skidpan-june-23/
wow, this is gonna be epic, good work driftmob!
can i pay a deposit now and the final of the payment closer to the date?
Cheers
yes thats fine but you will need to call and pay via credit because theres only 10 spots left
Yeah I still go through tyres on the wet ey.
At your last event I went through a set of rears and smashed the sidewalls of my fronts.
what car you driving ?
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
