Hi All,
the other night i bought a VL rolling shell, has everything but the eng+g/box,
it has everything ready for a V8 so it will be over kill for the straight 6 im putting in it.
There is no rust or chassis damage, its my Gf's uncles and he needs the shed space so he said $300 and its mine.. DONE!
someone told me today that there is a difference between a VL chassis for the in6 and V8; is that true?
koz my plan was to either put the full RB30ET in it or go for the RB30 head and RB25 block?
Whats everyone's opinions?
cant wait to get it started.
https://www.sau.com.au/forums/topic/400145-new-project-car-vl-rb2530-advice/
For a start the K-frame is different, the battery tray is on the opposite side and the fuel tank/lines need to be modded/replaced for fuel injection. If you are serious about this try the calaisturbo forum http://www.calaisturbo.com.au as it has a ton of information regarding all sorts of VL stuff. BTW I am guessing the hybrid was a typo surely you mean RB30 block with 25 head.
Edited by *LOACH*
yeah as above, really hoping you made a type with the engine and mean rb30 block with rb25 head.
why not just simply drop a rb25det into it? will make stacks more power than just a rb30et will (unless it has serious amounts of work)
No worries. Personally if I was going to convert a V8 VL into an injected track machine I would just spend the bit extra and get an LS1...heaps of torque for spinning the tyres and lighter than an RB. Later on you can turbo the LS1 and get 400rwkw without doing any bottom end work. Once again check the calaisturbo forum if you are interested in the LS1 conversion into VLs. K frames occasionally come up on Ebay or post on some forums to see if someone wants to swap your 8 for a 6....you might get some interest.
bit far out of my price range at the moment =]
thanks anyway.
Thread closed. Believe it or not, but since SAU started more than 7 years ago, this topic has been discussed before.
Please use the search function in future. It may be found here:
http://www.skylinesaustralia.com/forums/index.php?app=core&module=search&search_in=forums
While we understand that it can be frustrating to have your thread closed - Please consider that other members may feel it to be disrespectful and selfish of you to post a simple question, without using the search feature to review the wealth of information provided by said members over the years.
If you still feel that this action is unjust, then please PM me and we can discuss it further.
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
