Hi all,
I'm looking for 1 ADVAN RG in gold in 17 x 9.5jj 24. I've contacted most contacts in Japan as yokohama have stopped producing this one and now make the RGII. Mine has a crack in the spoke, which is apparantly unrepairable.
It looks like this.
https://www.sau.com.au/forums/topic/400155-wtb-advan-rg-gold-17-x-95/
