Hey i just bought another 33, and it has one of those so called "rare" Nismo LCD display dashes.
Basically, i don't have a computer system wired up to it. But i was wondering what system would be best to go for??? And where could i buy it/ how could i fit it???
Ive heard HKS Camp 2's are pretty good.
https://www.sau.com.au/forums/topic/400180-nismo-lcd-dash-need-help/
well the good news is the dash only needs an AV input, it takes an old fashioned NTSC feed.
So anything that puts that out would be fine, I used an epson ej-1. The HKS Camp 1 was not so great, but apparently 2 is much better. Or any other AV input like a car computer, rear view camera etc etc
Thanks for that :)
How would i go about wiring one of those bad boys in. I have no clue what to do, unfortunately
thankyou
The dash? It just needs accessory 12v, earth and the AV in which makes it beautifully easy to install.
If you pick a computer to go with it, that can get very tricky. THe epson EJ1 takes about 10 inputs from the computer.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
