All,
The last few mornings in Brisbane has seen the temperature drop.
My manual gearbox/clutch has experienced the strangest noise over the past 2 monrings while driving before all lubricants get to a decent operating temperature in my 34gtt coupe.
The noise is very hard to explain, but almost sounds like a kettle on the boil with a slight whistle when you give it some gas and when gauges get to operating temp it just stops, any ideas? *kind of sounds like air is being pressured out of a blow hole or something when you give it some gas in any gear!!
I know that the clutch needs a change soon, (standard clutch) and I am wondering if a component/bearing is feeling the cold weather??
I am parking it in the garage tonight to see if it is just temperature related as it has only happened on the last couple of coldest mornings.
Anyone out there had a similair experience??
Edited by lowbro
Hi Dan,
Yes at first I had thought that it may be turbo outlet related with the noise that was made but it so sounded like it was coming from the box, I did the park in the garage trick last night and the whirl/whistle noise was only there for a very short period before operating temps got up there and nowhere near as noisy as the last few morning, and guess what I have also noticed tonight, there is a dump pipe bolt missing at the turbo housing, so you could be exactly right that when it is really cold and the metals have not expanded before everything gets to op-temps then air could be making its way out and making this bizzare whirling/whistle type noise.
And guess which one it is, the darn bolt that is near impossible to get at on the inner/top right when looking into the bay from the passenger side ; (
Hmmm after searching the forums it seems I have a very similar problem. On cold morning starts it almost sounds like the engine is knocking quite badly, and when you pop the bonnet you can't hear the knocking but can hear a loud hissing coming from the passenger side area around the front of the exhaust. During the day or after the engine is warmed up the knocking and hissing sounds disappear.
Daniel,
if you could PM me a quote to change the exhaust / turbo gasket it would be muchly appreciated, car is a stock R32 gtst.
Cheers Mike.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
