  • Replies 41
agreed. Eventually.
You'll also notice your car might stall 'for no reason' at times depending on your driving style.
This is due to blocking the BOV.
The BOV is probably one of the only stock things that serves a half decent purpose (read: then I/C is crap as well as the stock turbo and the ECU to boot) I'd leave un-blocked.
https://www.sau.com.au/forums/topic/40021-the-flutter-sound/#findComment-819692
your gonna notice if yur getting back fire that you are most likely chewing petrol, and yes it will affect you turbo, there are a lot of threads covering this, look them up.. theres a lot of mixed reviews, bootom line is ur std bov was put there for a reason. i know of a guy doing this to his pulsar et turbo, then his engine blew.
its your risk at the end of the day
https://www.sau.com.au/forums/topic/40021-the-flutter-sound/#findComment-820113
Vl turbos dont come out with a bov, although i agree that they are there for a reason, i have had mine disconnected for along time now and no noticeable damage. Still goes alrite, um...at the end of the day if u want the noise without spending money on a ssq bov etc then it shte cheaper way out initially, maybe not in the long run.
https://www.sau.com.au/forums/topic/40021-the-flutter-sound/#findComment-820340
i had two ets. both were pretty worked. when you installed the aftermarket (bosch) bov we had to block the stock bov. which we did by unscrewing the bov off and blocking it with a large type of screw that fitted in place. trust me man. maybe the previous owner took your stocky off???
its good to see a fellow n12 owner though, i had heaps of fun in those little things, my fiorst car when i was 15
https://www.sau.com.au/forums/topic/40021-the-flutter-sound/#findComment-820555
Possibly... but the pipe from the turbo to the inlet looked factory. It was the start of my car hobby so wasn't as switched on about the ins and outs of turbo cars as i am now. But i never saw anything that looked like a bov. Mine was a 1984 model... perhaps they put them on the later models.
https://www.sau.com.au/forums/topic/40021-the-flutter-sound/#findComment-820619
so his exa didn't have a bov either? interesting that nissan would put a bov on the ET but not the exa...
as for the flutter sound, i would be a little warey about trying to get it. It slows your turbo down so it has to build boost again after the gear change. Especially bad with a bigger turbo so perhaps not so much of an issue with the stock one.
https://www.sau.com.au/forums/topic/40021-the-flutter-sound/#findComment-820748
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
