Hi All,
I'm looking to add some Camber arms to the V, with a fair bit of camber available adjustment.
Being that I know sweet fa about the geometry and available products, has anyone used or know about SPL, SPC, Cusco, Hardrace, Megan (or others)? Any knocking in the wells, issues with fractures etc? Ichiba/Godspeed seem to be the ones to avoid, so not considering them.
Looking at:
Front upper control arms
Rear Camber arms (upper/lower?)
Toe bolts?
Appreciate any assistance / advice
https://www.sau.com.au/forums/topic/400260-camber-kit-options/
Im running SPC front/rear camber arms and toe bolts. haven't had any issues with them. The front arms require you to reuse the ball joint seat though(the cone shaped black piece on the end of the A arm) mine didn't come off so i ended up ordering a new pair.
Im not running a whole lot of camber but its better then stock, i think my rears are around 2.0 and front 1.5 degrees.
Yeah they are the best for sure Big... NASA parts. Easy way to drop $1k on camber though... for front and rears.
Only reasons holding me back on SPL is the available camber range (they seemed lower than others, more for track correction I think) and the geometry (cant confirm if they knock when lowered this much, I'm flat on the lower rings all around)
SPC fronts are similar in design to the others (not SPL), but have poly bushings (not rubber) and put less stress directly on the weld seams (+1 internetz) Maybe I'll do the brake upgrade before I tackle camber. OEM Brembos for sale soon :)
CZP site is perfect, thanks for that one!
Big, change your photo man, gimme some new headlight action!
Yo Andrew,
Check your welcome post on ZClub. If you're only gonna get the camber kits then better to go through CZP yourself, however if you buying a lot of stuff best to talk to Paul. I've been eyeing the Akebono BBK for a while now, I want it! :)
Edited by 81gSKy
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
