Hey guys. I just starting having a problem wit my BOV. It's a turbosmart one. The car makes that fluttering sound now. When I rev it under the hood, I can see that it isn't opening. The car is running fine tho. No leaks around it that I can notice. any idea how I can fix this? Do I jus get a new one?
https://www.sau.com.au/forums/topic/400288-rb25-bov-problems-can-someone-help/
BOV is not designed to open unless there is a presence of surge pressure. Assume there is:
Firstly check and make sure the vacuum source to the BOV is after the throttle body.
If it is, then adjust the valve pressure generally controlled by a spring, like Peter said above.
Occasionally on a brand new BOV the thick oil sprayed onto the valve stiffens causing it to seize, use a wood stick genitally press in the valve and let it bounces back few times till unstuck or spray some WD40.
The tension is backed off all the way. Ive had this one on there for a few years and haven't adjusted it at all. When I took the car out yesterday it was fine, but when I drove home it wasn't working. Ive been told to try pulling it apart and cleaning it. It's a turbosmart dual port one. Anybody had any experience with doin this?
i had the same issue with my blitz one. You should pull the slide out and run some wet and dry paper around it (1200 grit) then get a socket the same size as the slide and move the slide up and down in the bov. Seemed to take about 10 times for mine to free up. Give it a go.
Sorted guys. Lol I called up turbosmart. They told me how to fix it. I took the bov off and undid the cap all the way till it came off. The spring poped out. I pushed hard on the piston coz it was jammed. Once it popped out you could see along the side of it, the spot where it was seizing. I jus used a bit of kero to clean all the crap off it and re-lubed the piston wit wd40 till it slid freely. Put it all back together and it's fine!!
According to turbosmart you should do this at least every 6 months. They even give you a video. Here's the link if anyone's interested. Cheers guys
http://www.turbosmart.com.au/technical-articles/looking-after-your-bov-or-bpv/
    • Sounds like the solenoid might be cactus, if the solenoid trigger wire was still attached (and it was just the main power to the starter itself remove). Just to provoke Neil haunting me for the rest of my life... Have you tried tapping it with a hammer while someone switches the key to start? This might work for the fuel pump too... šŸ˜›
    • I need help dealing with an engineer who is massively overcharging me for an engineering report on my modified, written-off Jeep to get it roadworthy. šŸ”¹ Initially, he quoted me $3,500 - $4,500. šŸ”¹ First invoice: $5,315 (already above the quote). šŸ”¹ Second invoice: $1,375. šŸ”¹ Now, he has sent another invoice for $3,100! This is way more than double what I was originally quoted. I feel like Iā€™m being ripped off. Has anyone dealt with something like this before? What can I do? Any advice on how to report him or fight these unfair charges? Would really appreciate any guidance! šŸ™ Am in Adelaide.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
Ɨ
Ɨ
