So my cars at the tuners getting the new GTX3076R put on with nismo 740cc injectors and exhaust. Its got a rebuilt bottom end with a re-co'd head. Its already got plenty of supporting mods such as Bosch 044 fuel pump, FMIC, Wolf 3D v4. Rang them up today to see how things are coming along and they say the cars detonating in the top end and they're not sure why.
So they asked me what kind of fuel I put in it. I put in a fresh near full tank of Caltex 98 right before I took it to them. They seem to think that may be the problem as Caltex runs a different blend of ethanol, possibly?
So they're going to drain the caltex and try BP ultimate tomorrow.
Can I get some input please, this is kind of worrying me and I'm questioning they're abilities.
https://www.sau.com.au/forums/topic/400306-skyline-detonating-on-dyno/
  • Replies 77
Posted Images
Let them check the fuel 1st then go from there. Did they mention the power it was making ? If around 270-280 at 18lbs it would seem about right. But if all goes according to plan there should be 290rwkws there. If the head was shaved I hope you used a 1.2 0r 1.6mm head gasket.
So you add 0.2-0.6mm for every 0.005" they take off the head?
No they didn't mention the power it was making, I forgot to ask. The wastegate is set to 14 or 16psi. Its a standard headgasket, pretty sure :wacko:
They built the motor in the hands of the previous owner so i assumed they would of known what they were doing. I hope so anyway.
I assume it should be, they're professionals, they should know what they're doing.
They didn't have time to try it today. They put fresh BP in but no time to tune it. Updates tomorrow.
You need to get your car outta that shop ASAP before they knock the bearings out of it (if it hasnt already) or worse... detonating in the top end = big trouble!! Its also the hardest to hear/detect so if they're certain thats whats happening i would be really concerned if i was you... To say they dont know why its detonating is reason enough for any person to question there ability. You need to ask questions like How timing have they put in at the point of det? What are the lambda readings at that point? If those questions arnt answered quickly and confidently then its obvious they dont know what they're doing.
It's sabbadin automotive if people are wondering. I tried to get into JPC but they were being lazy, arrogant regards. Customer service was the worst I've seen.
The tuners pulled the intercooler off and found oil in the bottom, so pretty sure the seals in the old turbo are stuffed. Cooler is getting sent away Monday to get cleaned. Hopefully fixes my issues.
Its more than likely just oil from the cam cover breathers. U may need a catch can to help prevent it filling up the cooler. Most cars will have oil in the cooler.
Is it blowing any blue smoke?
Is the cam timing and base ignition timing correct?
What intake pipe are u running to the turbo?
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
