Skyline Detonating On Dyno
Hopefully more pedal gives more powah! Boo to paint jail, I want dyno comparisons!
Sounds good. Might be worth double checking what size rim the tyres you are running want. Generally I'd expect to see a 235 tyre on a 8.5 rim. Any possibility of an easy to source OEM 9.5 wide rim? Also with the thoughts of the square setup, I'd still say wider is going to be better. Say your currently on 235 front and 255 rear. Going to square 255 will be better. But say you could fit, 255 front and 275 rear, that will be better again. In hypothetical land there might be a world where you go so wide that performance starts to go backwards, but I don't think you'll ever bump into that situation in real life. -
Found the answer: it wont fit without a bit of work- you'd have to change the guards as well
Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
