As a member of SAU with an HR31 and as the organiser of this day for HSV and NSCC, we now have 10 spots allocated to SAU for this day, which is almost full.
I have spoken with Eric and he is all for us offering this to you as he says many of you have never been to EC and this North Track has been made especially for Skylines (refer attached diag)!
Details and an 'email entry' and 'payment options' docs are attached. I can only give you a week (midnight next Thur) to email me your entry then whatever spots are left will revert back to HSV and NSCC as we will be more than full by then. Any more than 10 will go on a standby list. Please read the Supp Regs doc, which will give you full details of who is running the day, the format, timings, safety requirements etc.
Either post up or email me any queries.
Look forward to meeting some of you on the day.
Brett
North Circuit EC.pdf
Drive Day Supp Regs (Final) - EC_02Jun12.doc
DD2 Payment Options.doc
Drive Day Entry Form DD2 2012.doc
Well im going and i have signed up at least two other SAU peeps, with a third about to confirm his.
That leaves about 7 places left.
Im in the NSCC as well and these guys run an awesome track day, always a quick turn around of the groups to get you straight back out on the track and no stuffing around in the morning. Its all about maximum enjoyment of your car in perfect conditions.
K go!
Too little time to organise to get there for me, but the track looks very fast.
Maybe the HSV and NSCC clubs would like to attend the track day in Canberra on this Saterday, looks like lot of spaces left.
bit late for that, looks like we are getting a late rush on sutton road anyway. Hopefully can do another one day!
yeah Eastern will be mega fast, lots of room for skylines to stretch their legs. Going to be 8 or so groups of cars, ten minutes each group. Going from 9 am to 5pm so plenty of time i guess, plus a lot of the HSVs will have broken down by lunch..
:ph34r:
from what i have seen in vids and at the drift days it looks pretty epic. 2 straights, a few big looping corners, what more can you ask for?
(until the GP track is done of course)
With the track like that (I'm no expert) it should keep the emos and wrecksies in line, its only a couple of more corners than a oval.
Would be good for a HP RWD car with good driver, I've got the car but my balls are to small to go as fast as the car could take me.
just realised the fees not front and centre weevil
$210 for non HSV or NSCC members, 190 for members but how many folks in here other than brett and i pay forty bucks a yr to more than one club? I do it coz two track days a year just aint enough...living life. One minute and 12 or so seconds at time brah..
lol @ wrecksies and emos MLR, yeah we should make short work of them. I like to think im ballsy enough to find the limits of my 33 on the straight, corners are going to be ...interesting.
^ nice
not sure about 210 being that much, track costs about as much to hire as it did when it was the full circuit and i dont remember paying less than 300 very often. Its only really missing 4 or so corners compared to back in the day and has a longer second straight now, looking forward to it big time!
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
