turn 1 >.
Pat, club sprints are a lot cheaper. Im just being a tight arse and my monies worth is MRA - 6 races and 2 qualifying for $20 more!
although it is cheaper than the CAMS supersprint round.
Im keen to try the north - I think my aim is a 1.18 going off similar cars. Perhaps if someone towed me in the straights I'll go quicker haha
Guys, good to see some interest but I need your entries and payment if you are coming along (refer attached entry form etc). The day is now full with 98 entries but I am starting a waitlist as there will be the usual 5-6 cancellations so if you enter by tomorrow night you should get a run no probs.
I can assure you $210 with timing unit included for the North Track is a good value day that's why we are full two weeks out! Most clubs are charging from $190-$245 plus timer ($15) and some struggle to get their numbers.
I have already driven this circuit and it is a lot of fun - perfect for Skylines! There are plenty of challenging corners, like turn 1,3,the new 4 and 10/11. The only ones missing are the old turn 4,8 and 9.
Got it thanks Adam and you are No.3 on the wailist. I'm sure you will get a run as we always get about 5 or 6 cancellations out of a field of 98.
What's happened to Fatz's and MIR's entries - haven't received them as yet?
Brett
e: [email protected]
Brett
Mine still spat a little bit of oil on Saturday at Wakie, not much, only a few mills, but enough for me to drop my show bags and go back to the drawing board for a little while.
Hey Brian, you and Bianca still got the R32? Hope to see you out there then. Only got one entry from SAU which is a bit of a shame. Thought the guys would be right into this one.
Oh well, maybe the next one at Wakey on 19 Aug if nothing else clashes. Then we have a day at EC South on Oct 14, which again should be interesting.
Brett
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
