Hey guys,
Thinking of selling my RB25 i have built to get myself some cash, originally i got this motor out of an R33 in pretty good condition, but to get it up to really good condition i had the head reco'd at the cost of around $600 which included new inlet valve guides and stem seals, the exhaust guides had already been done, while the head was apart i also cleaned up the unnecessary lumps in the exhaust ports.
It all went back together with the following parts:
Performance Springs valve springs and retainers - $300
Camtech 272 Duration, 9mm lift cams - $1200
Tomei adjustable Cam Gears - $300 (not 100% sure i want to sell the cam gears yet)
ARP Head Studs - $150
New Durapro VRS Gasket Kit - $400
ACL Race Series big end bearings - $70
Also to go with this engine is a non-genuine Greddy Front facing plenum which i have gasket matched the runners to the head myself (needed doing really badly), and i have a billet fuel rail kit for this which allows the use of top feed injectors.
Together these cost around $500 and for the right price i can include some GTR Injectors aswell.
It also has a second hand Stainless highmount turbo manifold and Turbosmart 38mm Gate if needed, valued at around $500 for both items together.
As the engine sits it is currently a bare long motor, ready to have manifolds and accessories bolted on and put into use.
All up including the original price of the engine this setup owes me around $4500 but im willing to sell it for alot less than that so i thought i would see what kind of interest i get.
I can also throw in another r33 turbo bottom end with 1 melted piston for parts...
Also i should add that these cams are to suit an RB20 which eliminates the VCT, so this setup will drop straight into an R32 GTS-T using existing coilpacks, crank angle sensor, etc..
Or alternatively it would still drop into an R33 with minimal alterations.
I will try and upload some photos of the engine at some point.
Reason for sale is i sold the 32 GTS-T i built this for.
For any questions contact me on here or SMS me on 0408 117 171.
Cheers, Daniel.
Here are some pics of the build :)
The comparison photo of the 2 cam lobes is one of the 272's and a stock rb25 cam.
Also the turbo pictured has been sold and is not included.
May consider swaps and also may consider seperating the head from the block if someone is looking to build a forged motor and needs a head to put on it, this would also be a good head for a 25/30 build having no vct and bigger cams to help with flow for the extra capacity in the bottom end :)
with the cams, springs, gears and covers, it owes me around $2500 but would take $1800, the cams alone were $1200, would be happy to keep the cam gears and cam covers and sell it for $1500
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
