1995 Nissan Skyline R33 GTS-t Type M Coupe
5-Speed Manual Transmission
Black
92,000 Kms
Reg Until Jan 2005
Just want to point out (and members who have seen or been in my car can vouch for this), this is one of the cleanest/well cared for skylines around and its VERY upsetting to be selling it but time has come for me to think properly and make some investments etc until I have the money to splurge on another beautiful car such as this one. Car has been serviced religiously every 4-5000Kms. ICE Performance have done all the work on the car that I couldn’t (The ‘big’ stuff) and it has had a very recent compression test which ICE Performance did and showed the engine is as healthy as can be. Dyno Graphs of the various tunes can be shown/given with the car, last tune of PowerFC saw about 180rwkw on 0.85 bar (~10.5psi) with healthy A/F ratios. Would like to sell as is with the mods on the car for the price below but can negotiate a price without some mods or WITH some mods that aren’t on the car that I have.
$25,500 (Does NOT include mods off the car)
Exterior
TRUST Front Bar
Mspec Side Skirts
Mspec Spoiler
Tinted Windows
Weds RS-5 Deep Dish 17” Wheels
Interior
Custom Samurai Silver 2Pac Paint Job
Electroluminescant Speedomoter Dials (Blue/Green Changeable w/Dimmer)
A`Pexi 60mm Boost Gauge (Electroluminescant Blue Light Up)
A`Pexi ‘Pencil’ Turbo Timer
Rockford Fosgate 6” Speaker Grills
Isotta Steering Wheel (Italian leather) (Not Installed As Car has Airbag wheel)
Momo Shift Knob
Momo Racing Pedals
Genuine Leather Shift Knob/Handbrake Boots
Carbon Fibre Look Handbrake Cover
Nismo Floor Mats
All Interior Lights Changed To Blue (inc. Added Glovebox Neon, Aircon etc)
Engine Detailing
Polished Rocker Covers
Polished Turbo Heatshield
TRUST Engine Oil Cap
Various Blue Silicon Hosing
Performance
Pacemaker Front Pipe
Catco 3” High-Flow Cat Converter
HKS Super Dragger 3.5” Catback System
K&N High-Flow Filter
Exedy Heavy Duty Organic Clutch
C’s Short Shift Kit
TRUST V-SPL Front Mounted Intercooler Kit
Thermo Engine Fan (Removed Factory Clutch Fan)
A`Pexi PowerFC Engine Computer w/Hand Controller
TRUST ProfecB Spec II Electronic Boost Controller
Handling
Koni Adjustable Shocks (Stiffness Adjustable)
King Springs (Dropped Car 1inch, still legal height)
Brand New Bushes/Boots Installed With Suspension
Kuhmo 235 Front/255 Rear Tyres
Security
Viper Responder Paging Alarm System (Shock Sensor, Glass Break Sensor, Remote Engine Start w/Neutral Switch, Remote Boot Release, 3pt Immobiliser) installed by Danny (Autotrust)
Audio
Pioneer 6” Coaxials Front
Pioneer 6x9” Coaxials Rear (On Custom Parcel Shelf)
Maintenance Since I’ve Owned The Car
Exhaust Manifold Studs Machined/Replaced
Turbo Gaskets Replaced
Mods I Have That Are Not Installed (Sell With Car Or Separate)
TRUST TD06-25g Turbo Kit (inc. Turbo, Stainless Steel Manifold, External Wastegate, Stainless Steel Dump Pipe), wont separate (everything is TRUST)
Nippon Denso 550cc Injectors (Direct Fit RB25DET) *SOLD*
GTR BOVs
Symota Metal Pod Filter
TRUST Oil Catch Can (New Model BRAND NEW in the Box)
Standard Parts I Have That Are Not Installed (Sell With Car)
Standard Exhaust System (Full System inc. Cat Converter)
Standard ECU
Standard Boost Solenoid
Standard Pedals
Standard Speedometer Dials
Standard Air Panel Filter
Standard Shift Knob
Regular Skyline Goodies
Central Locking
Power Steering
Electric Windows
Electric Mirrors (And Fold-In Feature)
Aircon/Climate Control
HICAS 4 Wheel Steering
Electric Antenna
Independent Rear Suspension
Nathan - 0411 50 54 58
Cheers :(
Pics:
http://www.skylinesaustralia.com/photopost...500&ppuser=1732
https://www.sau.com.au/forums/topic/40037-black-1995-r33-gts-t-melb/
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
    • If I had logged into the forum and saw that I would have  Missed out again.
