Hi guys, im new to the site and know theres a heap of info on this but i cant decide which is the best choice for the set up ive been running :(
I have a 33gtst with a complete rb25det series 1 5spd manual, a few weeks ago i was giving it all its got down the motorway and all of a sudden heard a bang from the engine, lost all compression an had no response until it came to a stop, had a look and found a hole in left hand side of my block, its abit bigger than the size of a 52mm tacho face. It had a fully forged bottom, heaps of head work, bigger cams, injectors greddy plenum, nearly everything was replaced with aftermarket gear, 4inch exhaust, t04z ran 25psi low boost and 42 high making 690rwhp, using a custom made switch wired to the microtech handcontroller to change my settings. It was only on low boost when the engine failed. The guy i bought it off and that built it has sadly passed away and he was the only one that knew the car top to bottom and who i spoke to if i ever needed anything. Ive pulled it apart and the only thing wrong with the head is one of the valve heads has snapped right at the start of the stem. Conrod 2 & 3 have big chunks out of the left hand side where im guessing it hit the block. I was considering building an rb30 block, fixing the broken valve and fitting the 25 head back on top because of the lag i used to get, the only thing stopping me is ive been so curious as to why that wasnt done before, maybe the 25 bottom was more suitable for its setup? Any advice would be muchly appreciated as i want to get the rebuild started asap :) cheers
Will post pics of the hole in block, head and bottom end internals in the next day or 2.
https://www.sau.com.au/forums/topic/400370-rb2530-or-full-rb25/
after reading alot about the conversion and the high numbers its pushing out that is what im most keen on putting in it, just wanted to find out if there was a certain reason why it wasnt done before when they built the rb25 bottom end and pushed out just under 700hp, with all the parts i already have i should only need the fully forged 30 block and extra pin drilled in for the tensioner to complete the rebuild if ive read the topics correctly? If theres anything else im missing or should do before assembling please advise me :)
could be as simple as he already had the 25 and didn't want to change engine number, if you have to start from scratch with a new block then a well built, well balanced fordged 30 is going to give better results then a 25 anyday of the week, same technology more capacity.
you can run the standed idler and tensioner wheel locations with a 150 tooth belt ( but they get close ) or a 152 tooth belt and move the tensioner or idler wheel,
other wise just read as much info as you can, everything you need to know is here somewhere, reseach as much as you can and devise how you want to go about building one, I will say pay alot of attention to oil control and crank case venting as these done wrong can kill a RB quick
    • Hi, We've all posted some thread, or know of some other person's thread, that contains information that we want to send people who are asking question to. But if we don't have a link readily available, have to go do a search for the thread before being able to do so. So, it occurred to me that we could possibly utilise the auto-text-replace function that fixes some of my swear words to perhaps auto replace some special keywords with text that also has a link to the thread. A specific example. The thread that I did with the improved R32 GTR wiring diagram scans. If the phrase "R32 GTR wiring diagram" could be auto replaced with "R32 GTR wiring diagram" then all I (or @Duncan, or any of the others that refer to the thread) need to do is remember that that's the keyword (or phrase in this case). OK, it would be better if this keyphrase wasn't that long, but it does need to be specific enough that it doesn't get triggered automatically. And obviously there are threads on turbo topics, or suspension topics that we could treat similarly. Alternatively (and/or additionally), I've been thinking about trying to build a library of the real expert content that is trapped in the bowels of the 25odd years of this site. Things like some of SydneyKid's content. There are threads that he started that should be more easily found, and he has individual posts, or series of posts, in other people's threads, containing very good information. Some of us know that it is there, but....just have no memory of exactly where/when/how we saw it. If we had some sort of library thread, we could put posts in there containing links to things we've found, suggestions for how to categorise it, then a mod or other appointed thread maintainer can copy the link and any key text up into the first post in the library thread. There are probably many other ways to get it done. Some sort of wiki is probably the best way.   Thoughts?
    • But, probably that happened to the last person too, which is why the RTV was there.....if you aren't putting a new gasket in you will need to seal the old gasket back to the metal surface with something, the gaskets will generally only work properly for a single use as they set/harden in that shape
    • What is with the horrible blue and white bit in the centre of the wheels, didn't that come off with some scrubbing?
    • Not sure how broadly you define Northside  but Castle Hill Exhaust are still around and could sort it.
    • I haven't done this as I still use the factory cluster, but I do know the circuits for the flash vs on for hi beam are separate which is likely the issue. The ON runs full power through the switch and the flash uses the relay in the engine bay. I'd hit the wiring diagram per GTSBoy's suggestion
