Round 1 - Win Network Tasmanian Drift Series! 26Th May!
Hello again boys and girls!
It's that time of year again, ready to kick off our first round of the Win Network Tas Drift series.
26th of May - Baskerville Raceway
Drifting from 10am-4pm, gates are opened from 9am!
$10 entry for spectators, children under 12 are free wink.png - Lucky door prize to win a ride in a drift car!
I believe our lovely Drifting Tas guys and girls will also have hoodies available to purchase in the pits, so make sure you head over to the stand and start repping DT biggrin.png
We all pretty much know the drill, if you have any questions fire away. If not I will see you all there!
Regs, entry form and flyer attached below.
Entry Form (5).doc
Supplementary Regs.pdf
    • Curious to why you're not getting Jesse to do the exhaust, seeing that he has just done 2 GTRs with Aes valves.
    • What extra parts are you thinking you'll need to run e85 compared to e30?
    • I'm not aware of e30 in Australia, but I'm pretty sure e85 is still around. You really want a setup with an ethanol sensor so you can run any mix of ethanol depending on what you can access. Fuel Check NSW app shows 14 site in sydney metro with e85. What are you adding, will you put in bigger turbs too? Apparently the wastegates are pretty small and can't bypass enough as you run more boost.  I'm sticking to 1.3 bar with 98 on the standard turbos with my tune on advice from the tuner, and boost drops significantly in the top end; apparently larger turbos with larger wastegates are needed to get anywhere meaningful from there.
    • Amazing work Duncan! It is never easy to pick up someone elses project and work all the parts out that are missing
    • Hey Ppl,   I am about to tuned my Infiniti Q60 with E-85 and if you can tell me some location where I can top up my car that would be great.   But my other question, is E-30 available because this tuned requires less mods parts and any info you can offer would be greatly appreciated too!!
