Hi Guys,
Just got back from overseas and needed to start the car after letting it sit for quite a few months. Car was serviced before I left for overseas and has only seen around 100km's since that time (mechanic drove it from the shop and dropped it off, and I took it for a quick spin to get washed) and was running completely fine after the service. Today I decided to start the car and take it for another wash - It kicked over first go (I thought the battery would have drained by now but it didn't which was a good sign) - but I noticed it was missing heavily and very rough at idle (engine shaking/surging) - after a minute the car stalls. It did manage to kick over a few more times and has absolutely no problem starting - but continued to sound very erratic and kept stalling after a minute or so.
I've uploaded a short video, and while I know it's not the greatest and there are probably heaps of variables - I'm hoping someone might be able to point me in the right direction as to what to look for. There is no way I can limp it to the mechanics like this as it keeps stalling - so I'm hoping it will be a simple fix (leaky vacuum or something)? I did a search but doesn't seem like anyone has the exact problem I do nor on my engine.
The car is a 1993 R32 GT-R - it does have a powerFC and splitfires but standard injectors, pump, AFM's, etc.
http://www.filehosti...12/IMG_0466.MOV
I stopped the vid just before the car stalled.
I'll have to pull the plugs + AFM's out tomorrow when the sun comes up to check them - but if anyone has any advise before I start would be greatly appreciated (hoping to save my knuckles if I can)!
Edited by DEATH
As a side note - Car is not blowing smoke (weird seeing as it would always at least puff out one dark cloud on startup) - so not sure if it is running very lean now.
And it is quick to rev and is happy to rev up the RPM range (although you can still hear/feel the misses during this time and I haven't wanted to keep revving it alot and to very high RPM incase it is running lean and decides to go *POP*). So I don't think it is the CAS (but could be proven wrong)...
dont know how good fuel would be if it was left for a few months..
Mine sat for 8 months while I was overseas and didn't miss a beat. And my bike for nearly 18 months and was all good after 10 seconds of coughing.
Thanks guys - I have a feeling it is a vacuum leak or the PowerFC has somehow lost it's tune. I'm going to check the sparks/coils/AFM's tomorrow if I get a chance, just to rule them out - and going to have to start the slow process of removing everything to check all the vacuum hoses. If anyone in Melb (around Glen Waverley) wouldn't mind coming down with their PowerFC sometime to plug in to see if the car starts and idles ok - (will only take 5 minutes max or less if it's already out of your car) would be much appreciated.
Maybe a couple of your fuel injectors have siezed up? when i got my injectors cleaned the guy said that they can seize up and they need a tap to free them up. Not sure if that means removing them though, maybe someone else would know.
If you think bout it, nothing has changed its just been sitting there.
R33
One time - I forgot to tighten up my inter-cooler piping and this happened.
I found one of my vacuum lines went connected This happened
Also make sure all coil packs are plugged in #2 wasn't clicked right in for me and so it would still arck across some times but would miss and run rough
Edited by Luke stock R33
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
