So I've been searching this site and google for the past 4 hours - either my brain is fried (as it's almost 3am and all the threads I'm reading seem to contain people talking about RB20/RB25 GTST, GTT etc and mixing all the information and replies up) so can anyone tell me what the difference is between these model numbers?
BCPR7E
BCPR7ES
BCPR7EY
BCPR7EIX
DCPR7EIX
BKR7E
BKR7ES
BKR7EY
BKR7EIX
PFR7A
PFR7B
PFR7G
R5671A
R7238-7
R7436-7
I'm looking to replace my iridiums with some copper ones and from the list above what would suit a 1993 RB26DETT engine running 1.2 bar and splitfires?
https://www.sau.com.au/forums/topic/400437-r32-gtr-spark-plugs/
The BCPR and BKR plugs used over the various RB engines are very similar; one is an ISO standard the other a Japanese industry standard. Both are a resistor type plug and share a common tread width and pitch however the overall plug height differs; the RB20DE(T) & RB26DETT use a BCPR type the RB25DE(T) a BKR.
*The above is using NGK references
If you are looking to changing to a set of NGK copper cores to suit your R32 GTR (BCPR7ES) I can offer you a set for $29.04 + postage.
Thanks for the reply and information guys :) and yes I am going for heat range 7 Hadouken! :)
Picked up a set of BCPR7ES today from Autobahn for $29.94 ($4.99 each) - but thanks for the offer Kudos - I'll be hitting you guys up in the next few weeks though to get a few bits and bobs :)
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
