Wtb: R32 Gtr Genuine N1 Headlights (Pair) And D-Speed Full Clear Indicators
Hi Guys.
As stated above, I'm looking to buy a pair of GENUINE R32 GTR N1 headlights and also a pair of
D-Speed full clear indicators.
Now the N1 headlights have to be geniune with the mould plastic clips specific for the GTR, not the pov pack lights with the bolt on clips for the GTS.
Can anyone hook me up?
