Hey guys, I have a few ideas already but throw some at me.
ATM I'm getting 320ish a tank.
Mods are simple, fmic, boost tee with gauge, running 10pound with 3" catback system
Thinking of doing the 02 sensors first.
Cheers. ~ash
https://www.sau.com.au/forums/topic/400450-low-fuel-economy/
  • Replies 41
try getting some contact cleaner and cleaning the afm ( if you have one). I had the same problem when i first got my 33 and by changing the sensor and cleaning the afm im getting a lot better fuel economy
how about you tell us how many litres you are classing as a "tank". that will give us a better idea of whether your economy is just ordinary or extremely crap.
also, what sort of driving are you doing (city driving/highway driving) and how do you drive? if you do city driving and boost it often then you will get pretty crap fuel economy and no amount of changing sensors will help much.
Highway driving mostly.. I don't boost like an average wanker, i don't see a need in showing my car off to the 5-0 :P
I haven't tuned her yet, she's due when the money is here, so no management.
300ks to a full tank which is 40lts
ill do the afm and the throttle body when i get the 02 sensor in.
Cheers
40L isn't a full tank.
~13.33L/100ks, is not great, especially for highway driving. It is a skyline though... I get about the same but mostly driving in traffic.
sensors may help but even the minor mods you have done will mess with the factory tune somewhat. You're probably going to need a proper tune
yeah as above, 40L is a long way from a full tank. skylines have a 65L tank. you should have about 10L left when the fuel light comes on.
as for the economy you are getting, yeah that's pretty ordinary economy for highway driving. i'd start with your o2 sensor as that is responsible for altering the mixtures at light throttle. getting a tune won't help too much on highway driving (if the ecu you use still reads from the o2 sensor). you can check whether the o2 sensor is working correctly with a multimeter, or a consult cable.
it's also worth asking what size wheels and tyres you run, as that can make a noticable difference. big rims (17" and above) plus fat tyres will hurt your economy, as will running the tyre pressures too low. engine condition as well as fuel injector condtion will also have an effect. dirty injectors will hurt you economy (and a bottle of injector cleaner won't do squat), as well as a tired engine that is a little bit down on compression will also use more fuel.
If you have low compression that wont be helping, along with a stock computer which is always rich and retarded, maybe timing is out too, plugs maybe old,
a stock dump might be an issue too, i have a 3inch dump you could have $80,
i use to get about 600ks out of a tank with most highway, and that was front mount, exhaust, 10psi standard ecu
now im getting 300 on highway with a whole new setup, gt3040, full exhaust, 18psi, running wolf v500. Kind of depressing as its pretty much the same economy around town...
thats what i was thinking to, but it was the tuners prefered choice of ecu, and i let him know i was more interested in the economy for highway driving and didnt care about around town to much, I was talking to another person with same ecu tuned by the same tuner and they are averaging 550ks to a tank with more power than i am making... I just think its my car, seem to always have problems with something going wrong.
Thought I'd spend the doe and get a compression test done aswell. Booking that in with Pete at rpm.
I'm running 18" wheels with low pros federal/Heros.
I'm thinking it's bc my tank is not 65 ltr as u guys keep saying it is :P. don't ask why, it was like that when I bought her.
Thanks for the replies, several minds are better than 1 so I thought I'd check.
~ash
I dont think that tuner is giving you value for money, sounds like a rip off to me. I just found a new tuner and he could not believe the tune that had been done previously, no wonder the car had no top end, they had tuned it to be weak at the top.
taking someone elses tune and putting it in your computer is not a tune, thats what they can do and they know you have no idea. He should of tuned it for more than just highway. must of took half an hour that job.
Edited by SliverS2
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
