rb20x6 coilpacks 1 is faulty $100
r32 gts-t front guards one black other in primer $250
x2 r32 rear bumper $50
rear tail lights (no covers) $100
wagan boot spoiler for any r32 painted white brand new $250
starter motor $50
momo black plain steering wheel $50
r32 sunroof spoiler has a crack on the corner glue it and wont even notice it $150 very rare
gts-t boot no spoiler or lock. dark blue $20 will need a respray
r32 rb20 stock afm $100
hicas lock bar $50 fit most cars
bride brix 2 (i think) $600 can come with r31 rail.
Redback highflow cat $100. Used condition.
watanabes 15x7+27 all around ok tread. 4x114.3 slight bend in 1 100% useable
r32 white boot with gts wing perfect condition brand new paint $200.
Idale air valve control rb20 $50
Rb20 butterfly with tps $80
Rb20 tps $40
Rda r32 slotted rotors front pair only used for 20 days. Still have box pretty new.$180
Rb25 cas $20
rb25 coil pack cover $20
Rb25 90 degree elbow before fmic piping with bov. $50
Rb20 intake plenuim $50
Type r gauges and senders. All wiring all work. $150 the lot..
pickup hoppers crossing victoria.
can post most items anywhere in australia if you pay.
r32 dark blue boot::::needs respray $30
bride/recaro fixed seat adapter $40
sr20/s13 front pipe flex gktech brand $50
pair of rims 17x7+47 black look pretty good.
4x114.3 anz rims gutter rash on all average condition all passed rwc. really good tread $350...spent a lot on tyres.
r32 sunroof spoiler $150
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
