Hi guys, selling my complete RB26dett out of my 33gtr. I bought it to pass EPA because my other motor is illegal in every way and still wanted to keep it on the road. I purchased it about a month ago through Jap heaven in Epping. Its out of a 32 GTR. Comes complete with inlet and exhaust manifolds, turbo's, injectors, pretty much everything besides alternator, clutch and power steering pump. Its in the car at the moment, so comp test welcome before i pull it out. I paid $4000 so im selling it for $4000 and you can have the receipt with the engine. Runs fine and passed EPA with no issues and everything on it is completely standard.
Cheers Christian
0423 756 123
Bump, need it gone guys, it will be out by the weekend.
It includes
Complete running RB26DETT
Standard injectors and fuel rail
Standard coil packs
Cam/Crank sensor
Inlet manifold
Exhaust manifolds
Standard Turbo's
OS Giken Triple plate clutch and flywheel (worn but doesnt slip, still abit of meat left)
Water pump
Harmonic balancer
Sump and diff
Pretty much everything you would need to straight bolt in. Can come down and have a look at it, nothing to hide. Just a standard motor in good condition. Cheers
Photo's of the engine and receipt. Compression check was done on installation. most cylinders were just shy of 150psi and the lowest was about 144 psi. Healthy motor. Will send interstate if need be
